Results 1 to 10 of 11
June 25th, 2004 02:20 PM #1
mga bossing, kahit na 2 hrs ko lang park ang car(89 lancerglx) ko, may cold start problem na, whenever i start it, andar lang ng 1-2 secs then mamamatay na makina. i have to rev it first for a couple of minutes para tuloy-tuloy andar, kumbaga gusto niya painitin muna. 2 mekaniko na pinagdalhan ko, di pa rin alam remedy, btw na tune up na to 2 mos ago. wat are the possible causes and the remedies as well.thanks.
- Jun 2004
- 290
June 26th, 2004 07:17 PM #3if your experienceing rough idling and loss of power too. have your mechanic check you fuel pump in the gas tank. it possible that there is a prefilter in there that can ba cloged or maybe the pumb is not pumping enough pressure.
mintoy
- Nov 2003
- 190
June 27th, 2004 05:15 AM #5
carburated ba yun, kung curb baka barado try mo carburator/injector cleaner ..>>
June 29th, 2004 03:17 PM #7
bago ung fuel filter at contact point ko, pinalitan nung na tune up, pa try ko palinis uli yung carburetor at mga linya, at mga iba parts pang na mention nyo. tnx guys.
- Nov 2003
- 190
July 1st, 2004 11:34 AM #9Originally posted by groucho
iliad, balitaan mo kami kung carb nga ang naging problema.
July 1st, 2004 12:26 PM #10
in the meantime, ang ginagawa ko, i'm pulling the (auto)choke knob hanggang umabot ng 1000rpm para di mamatay makina at makakaandar nako immediately. sabi nung kasama ko yung ginagawa nun ay dinadagdagan yung fuel supply para di mamatay makina, kaso gastos sa gas.
Design & Dimensions: Exterior Refresh> Builds on current Kodo design with sharper, more...
2026 Mazda CX-5
