Results 1 to 10 of 10
    Has anyone tried this brand(Ginza) shock absorber? Much lower price than KYB and also Japan made( fluid type only). How does it perform? Need some feedbacks before i decide to buy a set.By the way, i'll be using it for my Corolla 91.
    Nov 2003
    get kyb para sure ka.
    Speedyfix, have you tried using Ginza brand or for that matter got feedbacks from your clients about its performance? By the way, would you suggest a gas type or a fluid type for my corolla. What i intend to replace are my rear shocks, so my front shocks are still the original. What would you recommend? Thanks in advance. PM me pala sa labor for replacing the shocks, i live nearby. I pass by your shop almost everyday, lagi kasi puno
    Apr 2004
    KYB na lang....
    Nov 2003
    carlos, nope, haven't used them yet pero it's hard to try out a new product with no rep. baka you'll end up spending twice pa and end up spending more than if you just bought the kyb's in the 1st place.
    i'd suggest going with the gas shocks
    sending you pm now.
    Aug 2005
    Kayaba tried and tested sakin stock pa to 10 years na.
    Is KYB still eveyone's choice? What are some of the options? medyo kulang ako sa budget but definitely, i won't go for surplus.
    Apr 2004
    check out monroe... IMHO, sulit talaga ang KYB's, proven!
    KYB gas for me. KYB wouldn't be an OEM supplier if their products didn't deliver.
    ok, thanks for the suggestion, i'll go for KYB. ipon lang muna pangdagdag
GINZA Brand
