Results 1 to 7 of 7
August 18th, 2012 05:38 PM #1
I had my car checked with a mechanic. he noticed na mataas yung clutch, so he adjusted it to the right level. he told me that i can still use the car but eventually, i will need to replace the "clutch something" (i forgot the term). huwag ko daw patagalin baka kasi may madamay pa na ibang parts like flywheel etc.
guys, what's your opinion on this. is he telling the truth?
August 18th, 2012 10:54 PM #2
it would have been bette if you did mention anong make ng auto mo, anong mileage rin nun at merun na bang history na ang clutch ay napalitan dati.
in my experience, kung normal wear and tear lang...the clutch lining will last you anywhere between 50,000 to 100,000km na takbo before it gets replaced.
exception dito ay kung clutch-driver ang user (meaning laging nakatapak sa clutch ang paa, that makes the clutch slip unnecessarily that leads to faster burning ng clutch lining), kung laging nasa ahonan ang sasakyan or kung merun ng factory defect ang clutch nuon pa.
- Jul 2011
- 262
November 11th, 2012 10:49 PM #3yung clutch ng pregio ko..napakatigas..cguradong ngalay o kaya manhid kapag naipit ka sa trapik. kapag nababad naman sa pedal minsan hindi maishift from first gear to 2nd gear or maski shift mo lang to neutral. applicable din kaya na solusyun ang post above..TIA
November 25th, 2012 02:12 AM #4
- Sep 2008
- 35
January 16th, 2013 07:15 PM #5have you replaced your clutch lining lately? you might have purchased a fake one. Always go for OEM or buy at reputable auto supply. Nangyari na rin sa akin ito. Found out that I bought a fake clutch lining. So replace ko lahat pati clutch pressure and release bearing.
January 16th, 2013 07:50 PM #6
obeserbahan nyo muna sir un clutch if di nagbabago since nun in-adjust usually talaga nasa age at mileage ng car malaman if due na un clutch assembly for replacement,best bet if sliding na kahit adjusted na replace nyo nalang
kung b14 na sentra gamit mo sir, pansin ko medyo talagang matigas un clutch kahit na replace na un loob ng tranny and clutch cable unlike ng older b13 model malambot un clutch, tama si sir mumuy buy OEM if budget permits
January 16th, 2013 10:46 PM #7
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
