Results 1 to 6 of 6
- Apr 2004
- 75
April 15th, 2004 11:03 AM #1What is the easiest, and effective way to remove those dried water drops in your car's windshield and windows?
April 16th, 2004 04:07 PM #2
tubig at sabon(detergent). then old newspaper para may pang tuyo ka.
glass cleaner
April 16th, 2004 04:56 PM #3
yup...madali lang yan..unlike pag sa body nangyari mas mahirap tanggalin..
April 16th, 2004 05:23 PM #4
kung di makuha sa detergent, glass clear o newspaper... pabuffing mo na yan. Gagamitan yan ng rotary buffing saka ng rubbing compound - yung fine grit. mechanical abrasion ka kailangan pag natuyo na kasi yung "water drops". actually dust yan na kasama ng water drop. pag evaporate ng tubig, literally naluluto yan sa ibabaw ng windshield dahil sa init.
if you have a hand drill, nakakabili sa ace hardware nung buffing pad (black and decker) na pwede ikabit sa hand drill. tapos bili ka na lang ng rubbing compound. apply the rubbbing compound on the windshield, then buff away at high speed. tanggal yun sigurado. ;)
- Nov 2002
- 67
April 17th, 2004 04:05 PM #5I remember sa true value may nabili ako na windshield polishing compound. its better than using the rubbing compound.
April 24th, 2004 03:19 PM #6
d makukuha sa detergent and water, rubbing compound ang solution nyan! or have it rubbed sa autoshop.. we do service it 350 ang charge or you can do i on ur own. just use the smallest grit rub-cpd
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
