Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Hi. May whining sound kasi yung Civic 02 namin kapag tinapakan yung accelerator pedal; naka neutral man o drive. Ano kaya ang posibleng problema? Baka may mairecommend din kayong gumagawa? Tapos naman na yung warranty, so ok lang na ipagawa na sa labas. Thanks. :D
    Apr 2006
    paanong whinning sound?
    baka slipping belt? need more info, medyo vague po eh.
    di kaya grounded lang yung electricals? medyo vague nga...pati sagot ko
    Dec 2003
    whining sound from stereo?
  6. #6
    Pag naka on lang yung radyo tsaka may whine? o kahit naka off?
    high pitched ba?
    baka nga sa belt, bearing or electical...
    turn off lights, radio....use a "hose stethoscope" kung gusto mong hanapin sa engine bay yung source ng sound...ingat lang at baka mahagip ng belt...
    Quote Originally Posted by ILuvDetailing
    high pitched ba?
    eto rin hula ko.. is it coming from the speakers? did you upgrade your sound system?
    if it is, alternator whine nga yan, maybe your power cables are too close to the speaker cables.
    Ay, sorry for the vague question. My bad...
    Bale yung whining sound galing sa engine area. Kapag tinapakan yung accelerator pedal, instead na yung usual growl lang nung engine, may kasabay na high pitched/whining sound. Kahit hindi todo yung tapak, kahit hindi hirap yung engine o mataas ang RPM, nandun parin. No upgrades done sa sound system, on/off yung stereo walang effect. Hindi rin lumalakas kapag kinabig to the left/right yung manibela, dati kasi nagkaroon ng mas mahinang sound na medyo hawig nung sa ngayon, tapos power steering fluid pala ang culprit.
    Nung huling checkup nito sa casa bago matapos ang warranty, yung isa sa mga mechanic napansin yung sound, so chineck lang niya para magkaroon ng idea. Hindi ko maalala kung anong fan yung tinukoy niyang possible na culprit, aux/related sa aircon, something like that. Pahapyaw lang niya sinabi, hindi kasi kasama sa usual na dapat gawin.
    Many thanks! :D
    Jan 2004
    belt slippage yata yan sir. either you have loose drive belts or worn out belts. ako 10 year old na yung civic ko once pa lang ako nagpalit. as for the power steering, meron nga talagang sound yun kapag nakaliko, that means to say your power steering pump is working. fan? electric ang mga fan for the cooling system at a/c. i wonder what fan that is.?
Civic Whining Sound
