Results 1 to 10 of 10
    mga bro... tanong lang. tinanong ko na mekaniko ko regarding my inquiry mukhang hindi rin niya alam sagot. kasi yung brakes ko (ABS-equipped yung car) kapag press ko brake pedal mahina kagat, kailangan ko pa ulitin pag-press. basta press then isa pa, ayun, sobrang lakas naman. sa pangalawa sobrang kagat. tingin nyo ano problem? sabi nung mekaniko baka daw brake pads. tulong mga pogi!
    OT: sensha na sa title, ala ako maisip e.
    Oct 2005
    i think isang madiin lang OK na for ABS equipped cars, kase ABS is more like a manual brake that automatically pumps/modulates the brakes for you.
    so pumping a brake in a non-ABS equipped car is equivalent to stomping the pedal to stop in an ABS equipped car, gets?
    hmmm... konti pa. what i mean is unang pump, ang lalim nung brakes parang di kumakagat, second pump mejo konting diidn lang kagat agad. malinaw ba explanation ko? kasi pati ako hirap mag-explain e.
    Oct 2005
    sorry if i misunderstood, akala ko you're pumping your brakes which shouldnt be the case if you have ABS.
    your ABS wont function properly and will result to a weaker performance.
    Aug 2005
    Try mong i-pump iyong hand brake para mag-adjust iyong pads or shoes. Pa-bleed mo rin iyong brakes mo baka may hangin sa system or pa-check mo rin ang buong brake system kung may-leak ang brake lines. Or bake manipis na ang mga pads or brake shoes ng sasakyan. Hope this helps.
    ok. salamat basti and corollado.... i'll try to check those tips ASAP!
    check fluid level. kung may problem ang abs system mo may light sa dashboard yan na mag lit. the pumping (hmm) action is normal for abs equip car but the deep (double hmm) pedal movement before your brake works is not. have it check asap.
    Quote Originally Posted by afrasay
    ok sir! noted na. will have the system checked tom. THANKS!
    Feb 2006
    may reapir kit ba ang ABS sa hydrovac? baka need replacement na kung de bomba na ang breaks
    Nov 2003
    you might have a leak. in which case you may need to replace the brake master. have it bled well tho as it is harder to bleed abs system compared to normal ones.
pumping action....
