Results 1 to 11 of 11
    Dec 2009
    Guys need advice, sumulong ako sa baha na lagpas tuhod pero mga 1 meter lang ang baha na part sa tunnel. Sinuwerte naman at hindi namatayan pero after 20mins naramdaman ko na pag tinatapakan ko yung clutch may parang vibration na feeling kada dinidiin. Pakiramdam parang may pumasok sa tubig. Ano sa tingin nyo ang dapat kong gawin? Many thanks mga sir. Btw 2011 adventure sasakyan ko
    Posted via Tsikot Mobile App
    Underwash, change transmission fluids. Check differential gear oil, repack bearings.
    Aug 2010
    Patakbuhin mo lang patakbuhin, wala naman bang nagbago sa performance? yung revo nga namin lagi din nilulusong sa baha pero ok naman...yung vibration sa clutch natural lang siguro yan, diesel e.
    Dec 2009
    How bout clutch fluid sir? Kakapalit ko lang ng transmission fluid at differential gear oil 2 weeks ago, papalitan ko pa ba?
    Dec 2009
    Quote Originally Posted by zap.FREEDOM View Post
    Wala naman sir. Same performance pa din. Nag aalala lang ako dun sa vibration sa clutch. Sige sir obserbahan ka muna kung mawawala yung vibrating nya.
    M/t are sealed transmissions. Medyo malabo pasukan ng tubig.
    Baka naging oc lang. Hehe
    Dec 2009
    Quote Originally Posted by [archie] View Post
    Ano suggestion mo sir? Wala naman akong dapat palotan na oil?
    Apr 2013
    Observe muna.
    Dec 2009
    Just got home. So far ang napansin ko yung alarm di na natunog pag nilock using keyless.
    Quote Originally Posted by radz15 View Post
    Depende kung hangang saan umabot baha. 1 meter is quite high, check fluids... Motor oil, brake, etc.
    Sama mo na check ecu kung medyo moist. Brake calipers if you feel something wrong sa preno like pigil yung takbo, may vibrate during hard braking.
    Feb 2009
    The clutch disc is probably still wet and will dry up as you use the car. Have the fluids checked. The transmission might have sucked water in while treading flood through the vent on top of the housing.
    Posted through phlpost.gov.ph
HELP!  Regarding sa clutch
