Results 1 to 17 of 17
    Dec 2004
    maingay yung interior ko. parang sa doors ata may nag vi vibrate na plastic parts. any tips on how to remove the noise?
    Feb 2005
    Kailan nag-iingay? When you're driving (on smooth roads? rough roads? uneven roads? when you hit a bump) or kapag sinasara mo yung door, maingay?
    Dec 2004
    pag umaandar may ingay yung front doors. pero pag idle may konting ingay yung front right door..
    Dec 2003
    try Wurth sound insulating pads, mdyo pricey pero it works. or flashband. mdyo matrabaho lng nga.
    Dec 2004
    para san po yung insulating pads? wala masyadong info sa site ng wurth.. di ko din kasi alam kung san exactly nanggagaling yung noise..
    Dec 2003
    have ur doorpads removed to check for loose parts, most likely u wont need any sound insulation if thats the case..
    does it happen at a particular engine speed? if so, it might be a tire balancing issue.
    good luck. this is the most frustrating thing, especially if you're an OC like me :D
  8. #8
    Sometimes its the wiring inside that makes the vibration. Do you have an aftermarket sound system installed? Thats also a problem for me, still thinking of a solution sans having to install sound insulation (medyo mabigat kasi kaya nagaalangan pa).
    BTW whats your car? Is it a diesel or gas?
    Dec 2004
    *M54 Powered
    random kasi pag nagkakaron ng noise e. usually habang umaandar biglang magkakaron. after a few seconds, mawawala. maya maya iingay nanaman. hindi naman malakas vibration ng engine especially when idle kaya mas nakakainis lalo kasi maririnig mo yung noise hehe.
    *ILuvDetailing
    stock lang yung sound setup ng ek civic ko e..
    Take off the door panel, take out all the plastic clips and get new ones. Tapos.
    Jan 2004
    inquire lang ako. saan makakabili ng insulating pads? thanks!
    what kind are you referring to?
    Dec 2004
    *theveed
    ano po yung plastic clips? mura lang ba yun? san pwede makakuha ng ganung clips?
    mura sobra yun... kahit anong autosupply meron.
    Oct 2004
    maingay interior ko kapag nalulubak.... wala nako makita problema.... kahit yung rb10 ko (pioneer box add on) secured naman. Must be the amount of audio cable in my dash? dami eh. hehe....
    Nov 2004
    pag sa casa ka nagpaayos ng dashboard and door noise magkano kaya aabutin?
    Jul 2005
    check mo lahat kasi baka may mga loose bolts and nuts sa interior mo lalo na pag lagi kang nalulubak.. yung mga plastic tabs minsan nagloloose din yun tapos while you're at it palitan mo na rin yung weather strips mo kung sa tingin mo hindi na ok...
noisy interior?
