Results 1 to 10 of 10
- Jun 2005
- 40
June 6th, 2005 06:44 AM #1guys,
my friend's car (proton) is is a little shaky at speeds above 80kph. and lumalabas yung "check engine" when driving above 80kph.
wheel balancing kaya kailangan nito?
June 6th, 2005 08:45 AM #3
possible reasons... loose suspension parts, tire balancing needed, or loose steering parts. take your pick :D
June 6th, 2005 09:22 AM #5
most probably tire/wheel balancing... have them checked at your suking mekaniko...
June 6th, 2005 12:05 PM #6
2 separate issues to.
yung sa shaking have you suspension parts checked. could be a combination of failing parts.
as for the CEL, kung walang ibang nangyayari, might be loose or dirty connections at the very least, but it could be worse as well.
June 6th, 2005 12:09 PM #7
maybe ur low on oil pressure somehow at high speeds? most of the time unbalanced tires/wheels is the main cause of shaking at high speeds.
June 6th, 2005 04:40 PM #8
shaking - buong body ba or mostly the steering wheel? check wheel balance, shocks or tire pressure or engine mounts or dirty fuel injectors.
Check engine - best to have this diagnosed on an engine analyser, pwedeng sensors lang yun. (wag naman sana ECU)
June 6th, 2005 06:48 PM #9
baka sa engine problem ,kailangan ng tuneup
or pa check mo mga balljoint, tie rod, wheel balancing,shock absorber connection,wheel bearings,steering box
rear drive ba yan ? check the crossjoint,bearings
June 6th, 2005 07:13 PM #10
hehehe ninenerbyos lang yang tsikot mo sa highspeed kaya nanginginig....
tsaka yung pag-ilaw nung ecu eh dahil sa pag-papanic nya sa sobrang bilis....herherherherherher
ika nga eh nerbyosa yang tsikot mo....herherherherhehrer
dyokdyokdyok lang pow.....!!!!
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
