Results 1 to 15 of 15
    Dec 2004
    Paano po ma-improve ang riding comfort ng isang old car like mine corolla XL 1992 big body. Ano mga factors na dapat i consider? may kinalaman ba ang mags (195/55 R15) and tire pressure (30 psi, too high?). tnx for all the replies.
    change shocks, springs and other suspension parts...okay lang yung 15" na mags...
    put sound deadening materials sa floor at pinto ng katawan para less road noise and vibration...
    dont forget lubrication...palit langis and other fluids on time para maganda takbo ng makina...
    dont use loud mufflers...
    Quote Originally Posted by nim ra
    well, first is what will you put first, comfort or "porma"/performance?
    If you want comfort first, you might want to consider changing your wheels from 15 inch mags to 14 inch and matching tires.
    30 psi tire pressure is just right.
    Dec 2004
    My priority is comfort. Nakuha ko po ng second hand ang kotse, so i guess my last option is to change my tire/mags. tnx for d reply sir ghosthunter.
    sir chieffy, how much po kaya ang aabutin kung magpalit ako ng shocks front/back? ano po brand maganda (reliable/cost effective)? ano po iyong "other supension parts" wala akong alam sa parts ng kotse eh. tnx for d reply din.
    Sep 2004
    go back to the stock 14 inch rims with 185/60/14 tires. this will definitely improve ride comfort. air pressure at 28 psi. sound barriers and a cold a/c are also a plus.
    May 2004
    Reliable and price wise na shocks KYB(Fluid type)... More or less 2K each....
    bilstien shocks. medyo mahal, pero sulit. don't expect to have a benz ride but it will definitely improve it.
    Aug 2003
    kung papalit ba ng shocks e kelangan sabay ung 4, or pwede 2 at a time(front/rear)?
    and is it ok to mix fluid and gas shocks, so long as ung pair of the same type is on the front/rear?
    tagal ko na gusto palitan ung shocks..di malabas labas ung pera B)
    yes... check the other suspension parts (such as bushings, cv joints, shock mounts, etc).
    that will cost a bundle it needs to be replaced.
    a slightly cheaper alternative to changing your alloy wheels & tires is simply to change the tires to a taller one. so if your tires are currently 55 series, a change to series 60 or even 65 will improve ride quality.
    Feb 2005
    i might be missing something here.. pero yun shocks ba e yun pinapalitan para maging lowered ang sasakyan? or something like that? kasi ive been thinking of changing my suspension and lowering it at the same time..
    you change the springs to lower your suspension. but to give a better and firmer ride, you also pair your aftermarket lowering springs with aftermarket/performance shocks ;)
    Sep 2004
    kasi nagpalit ako ng shock umabot lang ng 2k each sa front gas type ,tapos labor 300 sa banawe....tanong lang mga sir kasi bago ko pinalitan ung shock ko ,may tumutunog sa harapan ng kotse ko pag napapadaan sa lubak parang langitngit ng kama...then napalitan ko na nawala kaso ,pag bibiyahe ng malayuan parang bumabalik ung tunog..mga sir pasuyo lang kung may idea kayo..tnx
    drive slow as in slow, jok lang as what i know change springs, the wheel also matter , the gauge of the wheel as well
    Pagawa mo kay Zee, you'll save around 50-70% compared to changing parts :D
Improve riding comfort
