Results 1 to 10 of 14
May 12th, 2004 10:15 AM #1
puwede bang maglagay ng grease fittings sa bushing pin as in drill through the head and put zerk fittings and make a smaller hole through the length of the pin so as to allow the grease to come out of there?
in other words, make the pin hollow with a smaller hole at the shaft? or better yet, may nabibili na ganyan na? TIA
May 12th, 2004 10:58 AM #2
Meron naman nabibili na greasable shackle pins from Isuzu trucks, you will just have to bring your original part to get the exact measurement fit.
Are you planning to put it on the rear pins for your Patrol?
May 12th, 2004 12:33 PM #3
HI Ungas
no, actually para sa Samurai. yung saan nakakabit yung mga shackles. durog na kasi ang mga rubber niya and was thinking of poly pero baka madurog rin lang kasi umiikot di kagaya ng sa patrol.
May 12th, 2004 12:38 PM #4
Oh, sa Samurai pala, maliit ang shackle pins nyan. Pero meron nyan sa mga auto shops na greasable pins na para di ka na mahirappan pa magbutas.
May 12th, 2004 01:00 PM #5
thanks Ungas may alam ka ba kung saan? I tried dito sa jp rizal sa makati eh di nila alam daw yun
May 13th, 2004 02:43 AM #8
baka mahirapan kang makahanap niyan. maliit kasi siya compared to isuzu pins. 50 php lang ang rubber bushings kay Links.
May 13th, 2004 09:42 AM #10
called izuparts and they weren't very helpful
ano kaya kung patorno ko sa machine shop and have them fit yung pang grasa and drill a small hole sa shaft?
tapos pwede kong benta sa mga sammy owners din at cost :D
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
