I have a newly purchased used CRV 2003.For a week na sa akin yung unit and all the while naging problema. Then yesterday came namatayan ako ng makina sa Shaw blvd. All of a sudden ayaw nya na mag start. This is the first time i had trouble starting the unit. Tapos pinahila namin sa Taxi para iapakadyot and nagstart naman nung kinadyot na.
Eto napansin ko sa CRV. pag wala yung red battery indicator light. di sya mag-start,pero may redondo,but when you try so many times, say mga 5 straight times pati redondo nawawala na.
Kinaumagahan pag uwi ko i tried to start the engine,nandun yung battery indicator sa dash board at syempre nagstart sya. but when i turned it off to start again just to check, wala na yung battery indicator and ayaw na ulit magstart
I had it checked by a Mekaniko to find out what the problem is, kala ko nung una battery lang. pero sabi malakas naman daw battery ko. he tried to check some of the fuse under the Steering wheel while pulling off and putting back some fuse lumabas yung battery indicator and of course nagstart sya. kala ko ok na. but on the third try na i-start nawala naman yung battery indicator at syempre ayaw naman mag start.
everything is working.Headlights,wiper,radio,aircon,power windows,central lock, ilaw sa loob,hazard lights.pero pag start hangang redondo lang,ayaw tumuloy sa pag start.
ano kaya problema. please help.
