Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    To All Car lovers/racers,
    Install the new ALEGRE GAS OXIDIZER (EGO) at the tip of your vehicle's tail pipe and guaranteed to stop smoke belching, increase engine power (5 - 8%) and save on your fuel costs (up to 25%). Visit PHILTRADE (Roxas Blvd./Buendia Ave.) starting Nov. 26th - 29th, 2003 for this year's D.O.S.T. Inventors' Week. The EGO device is one of the finalist. We will be conducting FREE demos/testing on all vehicles and you could get the EGOs at discounted prices and more! See you all...
    Rene Bautista
    (0926)3031871 / (092)8740183
    :nerd:
    Jan 2003
    how much? may moneyback guarantee b yan?
    One time investment of Php 4,500 to Php 6,500 depending on model of EGO and your vehicle's engine size. Lifetime warranty with limited money-back guarantee!:nerd:
    What's the catch for limited money-back guarantee? :confused:
    The cost (PhP 150+) of welding the device is not included in the costs of the units. We can not refund said amount if you are not satisfied with the EGO. Also, damage to your engine (if any) as a direct result of the installation of the EGO, will be covered. We a sure you, there will be none, only benefits!:nerd:
    I am just curious what is the scientific basis for it - how would it work as you have claimed.
    Did you dyno the engines that you have used for it (before and after installation)?
    I couldn't attend the show, any alternative address to see the device as well as the proof that it works.
    Pasensya na po medyo metikuloso lang kasi ako pag ganyan ang claims ng product or equipment (medyo too good to be true kasi).
    peace.
    peace.
    HOW THIS BREAKTHROUGH INVENTION (EGO)
    WORKS EFFECTIVELY THREE WAYS...
    With the installation of ‘EGO’device (Alegre EXHAUST GAS OXIDIZER) to the present Conventional Exhaust System of an engine or vehicle, the exhaust flow velocity is increased tremendously by the “venturi” function of the device, causing more efficient “scavenging” in the engine’s combustion chambers. As a result, all the leftover wastes (unburnt fuel) and carbon deposits are scavenged and dispersed out during the exhaust stroke; thus, the subsequent intake of fresh fuel into the combustion chambers is assured to be in its ideal mixture or in the homogeneous state of “stoichiometric” air-fuel-ratio for efficient, full power combustion. This scientific innovation attributed to the ‘EGO’ device’s amazing accom-plishment, warrant an all-time peak engine performance, insuring:
    (1) Controlled exhaust emission to the safest level;
    (2) Substantial fuel and oil savings ( Gasoline from 25%- 30%; Diesel from 15%- 20%);
    (3) Remarkable power and torque increased (5%- 8%).
    Furthermore, the resulting effect of the exhaust emission’s increased velocity flow passing rapidly through the exhaust piping system and the ‘EGO’ device, causes partial vacuum in its “venturi” section, which automatically draws-in atmos-pheric air inside the device. In this process, oxygen from the inducted air reacts to the hot gases of exhaust; thus, further oxidation of the unburnt hydro-carbons take place, and in consequence, converts these noxious gases into harmless carbon dioxide, water and traces of Nitrogen as they are expelled-out clean and friendly to the atmosphere.
    Install One Now!!!
    Dyno Test ?- Yes.
    Pls call me at (02)8740183 ot txt me at (0926)3031871 so that we could meet for the actual testing. Where are you based?
    Rene
    :nerd:
    Jan 2003
    so cno may pang dyno test diyan. para ma try if this really works. then post nyo dito results
    Dyno test kay AutoPlus sa EDSA 500/test.
    Your info on how it works is quite "greek" .... I thought I knew enough about engines and how they work as well as the common terminologies in car craft....
    Constructive critisism lang - Honestly, that is a lousy way of doing a brochure text since an average non-techno reader/client will probably understand only 10% (at most) of the information.
    If I understand it correctly, the device is (sort of) capitalizing the exhaust flow rate (Sounds like a similar thing with turboes) to make the proper mixing of air-fuel in the (when it reach the combustion chamber) ideal state all the time. ). And since the ideal state of a/f is the best combination for fuel efficiency and power use....thus the efficiency in fuel consumption and "boost" in power.
    I am based up north of luzon (Angeles City) and still have some doubts about your claims. Posting the dyno test results (as suggested din by buknoy) would be a good way of enlightening us further.
    An actual sales pitch won't do me no good .... kasi ahente rin ako ..... sabi nga "ahente na...inahente pa".
    I would be convince, however, if your claims match your technical results.
    As of current, I am a believer of free-flow filters (like K&N, Simota), cold air intake (CAI) and intercoolers principle, turboes, and superchargers. So since your concept would be something of all these...I believe it is worth listening to.
    my 2 cents.
    Install One Now!!!
    Dyno Test ?- Yes.
    Rene
    :nerd:
    Without seeing the product my best guess is that this is similar to the one advertised in many car magazines. The one called "TORNADO", which is installed on the intake side and works on the same principle. A gadget which looks like a fan blade but is fixed. Air passing thru it follows a spining effect which increases its velocity. Am I correct?
    Nothing can minimize smoke belching better than having your injection pump recalibrated as well as the injector nozzles. Also to eliminate smoke belching the engine will need good compression and correct fuel injection timing timing. Include in that a clean air filter and regular change oil.
    Jan 2003
    add616reneb
    r u willing to submit to dynotest sa autoplus?
    add616reneb
    Sent you e-mail re: all tests conducted on the EGO by Gov't. agencies, etc. including the Dynotest/autoplus.
    BTW, the EGO recently won FIRST PRIZE (Likha Award) in this year's National Inventors Week held at PHILTRADE, Nov. 26th - 30th, 2003.:nerd:
    The EGO is not similar to the "TORNADO" because is installed/ welded at the tip of your vehicle's tail pipe, hence no engine modification required. The increase in the exhaust gas velocirty is due to the "venturi effect' which causes the device to act like a vacuum cleaner which sucks out all the unburnt fuel, carbon deposits, etc. in the exhaust system including those in the combustion chamber. The incoming air + fuel mixture will always be ideal, hence commbustion is almost complete resulting to increase in power and fuel savings. Secondly, as the exhaust gases reaches the EGO device, secondary oxidation occurs as fresh air is sucked-in and mixed with the hot gases/hydrocarbons resulting to carbon monoxide and nitrogen oxides turning to harmless carbon dioxide, water and nitrogen!:nerd:
    as i understand it, it is affixed to the exhaust pipe of the vehicle. now, there is 1 point that I just can't reconcile in my engineer's mind.
    "The increase in the exhaust gas velocirty is due to the "venturi effect' which causes the device to act like a vacuum cleaner which sucks out all the unburnt fuel, carbon deposits, etc. in the exhaust system including those in the combustion chamber. "
    This statement alone suggests to me that this is one of those "perpetual motion machines" that, time and again have been proven not to work. A venturi effect is the effect in the change in velocity of a gas moving across a conduit (such as a tube or pipe), from a low velocity to a high velocity due a constriction in the pipe. By the principles of Bernoulli, a constriction on a moving volume of gas equates to a change in volume of a confined gas. Since the gas is not in fact confined but in motion, this results in increase in velocity. The increase in velocity results in higher dynamic pressure losses in the constriction, thus the "vacuum" effect. This vacuum however is on the WALLS of the venturi body. It does not affect the end of the pipe from whence the air came from (the engine). SO HOW DOES CONSTRICTING A PIPE RESULT IN INCREASED VACUUM IN THE ENGINE EXHAUST PORTS???? How does the gas being expelled from the engine "vacuum" itself???? Where did the energy to do this come from? That is why I think first of a perpetual motion machine, because the energy for the work that you say occurs does not seem to have a source. If you tell me that increasing the velocity on a constriction results in vacuum pressure at the exhaust ports several feet away from the device, then maybe I must go back to engineering school again. On the contrary, constricting the exhaust should result in higher back pressure on the engine ports.
    Send me an e-mail at: add616reneb*cyberlink.net.ph so that I could give you literature/diagrams/brochures about the EGO so that you will understand better.:nerd:
    Just a reminder add616reneb, I am not saying your device does not work per se. I am challenging your claims, as all claims have to be challenged, scrutinized, tested, experimented and thus PROVEN. If it will not pass the questions of this board (tsikot.com) then how will it pass the scrutiny of those who will put up the money to manufacture your invention? Gets mo? They for sure will be looking at it under a maghifying glass before they put their money where your mouth is. Claims are claims, scientific facts are facts.
    The EGO has scientific basis and if it not so, it could not have won FIRST PRIZE in this year's National Inventors' Week Competition held recently at PHILTRADE only last Nov. 26th - 30th, 2003. It passed thru all the testings conducted by concerned Gov't. agencies (DOST, DENR, DOTC, etc.) as well as private entities!:nerd:
    sent you an email. sagot na agad dali tutulog na ako hehe! need to pack my bags pa!
    Sent e-mail already. Thanks for your interest. You could buy the EGO for only Php 4,500 (small cars) - Php 6,500 (air-con buses/ big trucks) depending on model and sizes of your engines (excluding costs of welding).
Alegre Exhaust Gas Oxidizer (ego)
