Results 11 to 17 of 17
December 29th, 2004 10:20 AM #11
as long as not in the tip ok pa ang engine, you should only be alrmed if the tip is wet of oil. there might be oil condensation lang and when you had it washed it mixed with the water and went to the sparkplug.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 30th, 2004 11:08 AM #12oil seals are cheap lang. maybe between 100-150/pc estimate ko. even if isang lang basa, i recommend replacing all 4 na since nakabukas narin.
- Nov 2003
- 3,848
January 4th, 2005 11:47 AM #14you can actually diy it or pay a couple of hundred lang for the replacement at your suking talyer. kasama na dun linis ng VC and everything else dapat.
- Nov 2003
- 3,848
January 5th, 2005 11:40 AM #17hehe! tawag ka nalang kay toto... he can give you the complete breakdown para ma-fix na yung price
seeya!
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
