Results 1 to 10 of 16
- Feb 2004
- 5
February 29th, 2004 01:33 AM #1When I opened the engine oil cap of my toyota corolla 95 nag shower ang langis, wala namang usok na lumulabas sa tambutso, at maganda pa yung hatak. Blow by na kaya to? :confused:
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 1st, 2004 10:26 AM #2umaandar ba yung engine nung binuksan mo yung oil cap? if so that would explain bakit sumabog yung langis. the engine is pressurized and opening the oil cap when the engine is running isn't a smart thing to do.
i think ok pa makina mo.
- Feb 2004
- 24
March 1st, 2004 11:10 AM #4umu usok at may pressure na lumalabas pag pinul mo yong deep stick mo o pag binuksan mo yon oil cap mo may presure din at the same time /bye bye engine na :D
- Feb 2004
- 102
March 1st, 2004 11:21 AM #5mga pre, tatanong ko na rin. yung 96 xe ko ang lakas sa langis. pag nagdagdag ako ,usually 1 liter. i could see some oil sa paligid ng engine. ( pero hindi naman mga 1 liter ). i recently bought this car, it has 100+ K mileage but ok pa naman at wala akong complaints sa takbo.
is this what you call "pumping oil"? anyway, what i'd like to know is the cause. could it be the improper maintenance/driving habit of the former owner or just simple wear and tear ?
- Feb 2004
- 24
March 1st, 2004 02:49 PM #6ok ganito yon dalawang problema mo right know{a} kung tumutulo sa paligid it means meron seal na wear out posible suspect front mainseal ,rear mainseal or oilpan gasket subukan mo munang i fix yon mga leak see if ill go away,(b)hanapin mo ako o e pm mo ko kung meron parin.
- Nov 2003
- 3,849
March 2nd, 2004 10:53 AM #7if the engine is dry but kumakain ng oil then this means the piston rings are going kaput.
if may tulo, then have these fixed kasi in the long run mas mahal yung dagdag ka ng dagdag ng oil.
blow-by is when there is smoke comming out of the oil hole when the engine is running. compression testing is the easiest way to note if the engine is in good health or not.
- Feb 2004
- 24
March 2nd, 2004 03:55 PM #8Originally posted by speedyfix
March 2nd, 2004 04:25 PM #9
Check also the tail end of your exhaust...kung may langis na sa dulo...bad sign....blowby
July 1st, 2004 12:38 AM #10Originally posted by kilawind
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
