Results 1 to 10 of 14
- Aug 2006
- 19
October 13th, 2006 10:43 PM #1mga sirs,
kaka pa tune up ko lng pati change oil pero wla ata sa timing...
pag alis ko sa shop e ok nman ang takbo(siguro dahil mainit makina) then i parked it for 5 hrs. tpos ng gamitin ko na sinisinok na.may kanyon pa ko sa tambutso pag inaapakan ko gas.
ibabalik ko liteace ko bukas..
ano kaya naging problema dun?
pwede bng gamitin ito khit masama pag ka tune up?
thankss for future advice
October 14th, 2006 07:14 AM #3
Balik mo na agad yan para masilip. Ano bang ginawa besides change oil? Palit spark plug? Palit air filter? Chineck ba ang timing? Carb ba? Pinalitan ba contact point kung meron?
- Aug 2006
- 19
October 15th, 2006 08:48 AM #492 liteace 5k carb,nagpalit ng contact point,condenser,air*gas filter,spark plug.tiniming rin
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 15th, 2006 04:41 PM #5malamang wrong timing or improper installation of the contact point etc...
Toyota is my choice
- Aug 2005
- 2,063
October 15th, 2006 09:50 PM #6uhmmm.. bad tune up talaga yan sir..
dapat ginamitan ng timing light and todong revolution para sa tune up.. kasama na saktong rpm..
itong style ng mechanic na sure tune up..
rev rev.. broom broom.. use timing light.. then .. adjust timing.. vroom vroom vroom vroom.. hangang hindi sinsi-ok ang engine..
Zombie
- Aug 2006
- 728
- Aug 2006
- 19
October 16th, 2006 11:28 AM #8nabalik ko n po yung liteace
the problems are:
- faulty condenser,reject daw ata yung nabili ko kaya ibinalik n lng yung luma
- bad timing, bagito daw kasi yung tumira.tsaka tingin ko inabot n kmi ng 5pm kaya nagmamadali hindi nga nalinis yung air filter e
- barado daw carburador, pero nung nilinis nila nkita ko sinisinok p rin tsaka prang mahina daloy ng kuryente
- spark plug,binalik yung luma bka daw yun ang problema,pero hindi nman kaya bagong spark plug na ang gamit ko from ngk to bosch yung local lng
October 17th, 2006 04:47 AM #9
don't go to any shady repair shop... and use only original parts...
tignan mo nangyari... waste of time, waste of money...
October 17th, 2006 09:03 AM #10
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
