sa tingin niyo may kulang ba na parte dito sa air intake ng van ko or ganito lang talaga ito? meron pa kayang naka konekta dito sa tubo na ito? :confused:
sa tingin ko sir parang kulang po siya. I think it should make a turn to the hole in the left side so that it can suck in cold air from the outsideBTW what kind of a van do you have sir : )
Yung sa Besta ko ganyan din lang. For sure hindi kulang yun kasi pare-pareho sila ng ibang units.
Ewan ko lang itong sa Grace.
Intake yata yan going to the filter. Mukhang hindi naman kulang. Yan din kasi ang position ang location ng air intake ng pick-up ko eh.
thanks sa mga nag reply kasi kung titignan parang kulang kaya tinanong ko dito.
usually may mga pipe extension lang yan to direct the flow of air from the front or any convenient location..
that pipe was intended to be connected dun sa side grill (near the door) to suck in air. but due to floods the manufacturers opted to just cut it and just let it suck air in the engine compartment, just to prevent it from sucking in water incase the driver in bold enough to drive thru flood.
sa besta ko may naka attach na canister that traps heaveir-than-air particiles from getting ingested... sort of ain air-filter i guess...![]()
