Results 1 to 10 of 10
    Guys, tanong ko lang kung nangyari na sa inyo ito. Since tag-ulan ngayon, laging basa ang auto at napansin ko lang na meron akong naririnig na tubig sa may door ko habang nagddrive lalo na kung magbbrake or mag-accelerate. Parang may batis sa loog ng auto ko kahit tumigil na yung ulan. Parang naipon sya sa loob ng pintuan. Weird to pero tanong ko lang baka me idea kayo.
    Nov 2007
    hindi kaya ito yung kanal ng aircon ano po ba ssakyan nyo?
    ^nope, sabi niya driver's door side eh, kung drainage ng A/C dapat sa passenger side...
    *TS, hanapin mo yun drain ng door nasa ilalim ng pinto mo malaman barado na, meron butas sa ilalim ng door sundutin mo lang yun ok na
    korek si shadow, sundutin mo yung mga drain hole sa ilalim ng bawat doors. malamang puno na ng lupa kaya umaalon
    meron akong nakitang butas sa may ilalim ng driver's door, pero di ko alam kung yun nga yung labasan ng tubig. Anyway, check ko na lang ulit. Salamat.
    Quote Originally Posted by jusipus View Post
    yun na ang drain hole wala naman ibang butas sa ilalim ng doors, sinundot mo na ba?
    Just check the drain holes under the door itself. It could have gotten clogged by dirt or rustproofing material. Anything small and pointed can be used to push through the clogged hole to let the water out of the door.
    BTW, the water might not be in the door but in the side skirts if your car is equipped with such. This is especially true if you have driven through some flooded streets. To remove water there, you'll need to remove the side skirts. An auto shop would be handy for this because reinstallation would require two people.
    Apr 2005
    Don't worry, kapag umuulan lang naman yan.
I hear water flowing on the driver's door
