Results 1 to 4 of 4
    Mar 2013
    Hi Folks, Honda CRV 2017 matic napansin namin medyo agresibo na andar from stop to drive(pagka bitaw ng brake)
    kung dati nung bagong bili hanggang kahapon pag park->drive->bitaw brake ang andar gapang lang pero ngayun ga-lakad na ang bilis.. wala namang ginalaw.. praning lang o normal to sa matic?
    Let go of the brake pedal slowly. If it crawls too fast maybe the accelerator sensor needs to be checked. Bring to your nearest honda service center.
    Mar 2013
    OKay ty sir. Nga pala may obd2 sensor ako using torque light (android app) wala naman daw fault code sa ecu
    Mar 2004
    There many types of OBD2 diagnostic tools. Cheaper ones can read common codes only, more expensive ones can go deeper into the system.
Honda CRV 2017 accelleration gapang to lakad
