Results 1 to 10 of 10
- Oct 2007
- 7
November 25th, 2007 08:05 PM #1naglalabasan na yata sira ng oto ko, its a 96 model 2.0 car A/T. napapansin ko, parang ang bilis nyang maubusan ng langis sa engine, mga 2 months ago lang kaka-change oil lang nun, naubusan kaagad ng langis, normal ba un?
saka kanina lang, kala ko nga di na ako aabot ng bahay, para syang nanginginig na parang kumakadyot kadyot, ano kaya posible problem nya? tapos hirap na hirap syang umakyat lalo na pag walang preno, one time nga, halos huminto na ko paakyat. kanina, sobrang hina ng hatak lalo na yung binuksan ko na yung AC, todo tapak na ko pero parang kulang na kulang sa bilis, ang bagal ko talaga.
mga sir, please help me naman, ano kaya posibleng problema ng oto ko? kakapa-reserface ko lang ng makina mga 2 months ago. dapat ko bang ipa-compressor test yun? after bang i-reserface ng oto, ano dapat gawin after break in period?
thanks po!
November 25th, 2007 09:22 PM #2
Sounds like you have an oil leak, possibly at the piston ring(s) if you cannot spot oil leaking out of the engine itself. Best to have a trusted mechanic check your car's engine. If you dont have one, you can bring it to a shop like SPEEDYFIX (along Shaw) or SPEEDLAB (along Quezon Ave).
Is your exhaust smokey?
Anyway, from your description, you'll probably need to have it overhauled (if the problem is from the piston rings).
BANNED BANNED BANNED
- Aug 2007
- 999
November 26th, 2007 04:56 AM #3question lang....Ano yung meaning ng kaka resurface lang pag dating sa engine?
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 26th, 2007 10:40 PM #4you had it overhauled na? looks like a bad job was done kung ganyan sya. have it checked by any competent mechanic siguro so you know what is wrong with it.
- Oct 2007
- 7
November 28th, 2007 02:23 PM #5yes, overhauled na sya. ni-resurface ung makina, so dba dapat para na syang bago uli? dapat dba mabilis sya at hindi mahina humatak? pinalitan lang kasi yata ng gasket tapos minachine shop ung engine. sa pagkaka alam ko, hindi yata pinalitan yung piston ring. para san ba ang piston ring? magkano kaya magagastos sa pagpapalit ng piston ring? thanks!
- Oct 2007
- 7
November 28th, 2007 02:30 PM #6sa tingin ko nga piston ring ang problema kasi wala naman akong nakikitang leak eh pero nagbabawas ng oil. question lang, kung na-overhaul na sya, pwede pa bang palitan ng piston ring un?
November 30th, 2007 09:22 PM #7
check if there's an oil sa exhause pipe mo and kung may white smoke sya. Baka nga piston ring yan sir. sayang yung last na pagawa nyo sir dapat na check yan ng mekaniko mo. Try mo kina sir speedyfix.
- Jul 2003
- 573
November 30th, 2007 10:50 PM #8normally,pinapalitan din ang piston rings para lapat sa bore at tama ang gap.
kung kalog na ang piston, next oversize na dapat yung bore, palit piston at piston rings. medyo malaking gastusan ito.
- Oct 2007
- 7
December 1st, 2007 12:30 AM #9naku kung malaking gastusan, mga magkano kaya aabutin? pra sana ma-budget ko na at mapag ipunan.. kasi isang linggo ko narin di ginagamit yung oto, takot ako baka maabutan ako ng sira sa daan.. plano ko na nga kay Speedyfix mgpagawa, dami narin kc nagre-recommend, gusto ko lang tlga mpaghandaan kung mga magkano aabutin para isang puntahan nalang din.
pwede ko pa kaya syang i-drive kung mdyo nagcho-choke sya na nanginginig yung feeling? di kaya maabutan ako ng sira sa daan?
thanks s inyong lhat!
- Nov 2003
- 3,848
December 2nd, 2007 09:40 PM #10it's kinda hard to say how much it will cost without opening up the engine. you have to see kung kaya pa sa rin or pati piston palit. same din sa sleeves... if you need to resleeve mahal na yun.
I would lean more towards technological solutions instead of deputized traffic wardens, whenever...
SC (temporarily) stops NCAP
