Results 1 to 10 of 17
October 11th, 2004 09:26 PM #1
tsikoteers, last month ko pa naamoy yung sunog sa loob ng kotse ko. inamoy ko yung makina pero hindi naman amoy sunog... sabi ng kabarkada ko baka daw sa transmission yun. hindi naman pwede brakes kasi ok pa naman siya.. anu sa tingin nyo? matic pa naman kotse ko. thanks in advance :D
October 11th, 2004 09:32 PM #2
Ano po bang klaseng amoy sunog? Plastic na sunog, fluids na sunog, carpet na sunog?
Baka naman fuse? O kaya naman wirings na nag-iinit kaya amoy sunog yung insulation?
Magdala na rin kayo ng portable extinguisher, just for emergency situations. :D
October 11th, 2004 09:36 PM #3
Natiis mo na isang buwang amoy sunog ang kotse mo? Grabe!
I'd also have the electricals checked if I were you. Mahirap na. Kelan lumalabas yung amoy, pag naka-idle ka o pag umaandar ka na?
October 11th, 2004 10:13 PM #4
have you electricals checked as soon as possible. It would probably one of the inside electrical equiptment that is the cause of the burning smell.
- Jun 2004
- 1,311
October 12th, 2004 12:32 AM #5check your engine oil level and automatic transmission fluid level, then smell the ATF if it smells burned or not, if yes you need to replace it and have the tranny checked. other possible burning things could be wiring, esp. if new electronics had been installed.
October 12th, 2004 02:04 AM #7
thanks sa reply! hmm, sabi ng dad ko baka daw sa electrical wiring. nadrive ko naman kanina pauwi wala naman amoy kanina. madalas mangyari ang amoy kapag traffic at umaga (sa init siguro). and yep tama si ungas, magdala na raw ako ng fire extinguisher sabi ng dad ko.hehe bukas papacheck ko na sa tire boy and sana maayos na :D thanks ulit!
October 12th, 2004 03:28 AM #8
how about nangangamoy clutch pag umaabot na ako ng 120++ kph?? anu cause nun? ganun kasi nangyayari sa car namin, para din siyang amoy sunog eh hehehe
October 13th, 2004 03:41 AM #10
uy tsikoteers, napacheck ko na kanina sa tire boy kung ano ang problema. wala daw nasusunog sa kotse baka lang daw yung mga goma na nabubugahan ng pressurized sa car wash (every sunday pa naman) na pwede daw dahilan kaya parang nawala sa alignment sa kaha kaya kapag mausok sa labas madili pumasok sa kotse, or yung sa thermostat, minsan daw nalalagay sa bandang gitna kaya umiinit ang aircon at nagaamoy sunog. kung may nasunog daw na wiring or ano sa kotse malamang daw d na ko makakarating sa tire boy nun (oo nga naman,hehe) anyway, thanks sa reply ninyong lahat! :D atleast kapag actual na talaga alam ko na kung ano.hehe
pissword, hmm, wala ako alam sa manual transmission pero kung ako sa iyo pacheck mo na lang. delikado na kapag ganyan e...
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
