Results 1 to 7 of 7
- Apr 2007
- 66
May 27th, 2007 01:00 AM #1Guys, Ndi ko alam kung may problema ung gamit kong lancer kc pag apak ng 3k+ ung rpm parang awlang dagdag hatak lumalakas lang ung tunog ng engine. normal ba to? or may problema?
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 27th, 2007 09:02 AM #4
dalhin na sa speedyfix yan!!! ...I just went there yesterday by the way. problem solved.
- Apr 2007
- 66
- Nov 2003
- 3,848
May 27th, 2007 09:31 AM #6how can you estimate how much will be spent if hindi pa alam what the problem is with the car?
May 29th, 2007 02:47 PM #7
kung clutch ang problema, prepare to spend around 3k to 5k depending if you will use original or replacement parts.
you will have to replace kasi a number of parts para isang trabaho na lang like, clutch disc, pressure plate, release bearing and rear crank oil seal. that is kung sliding clutch na ride mo.
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
