Results 1 to 5 of 5
- Jul 2010
- 28
July 15th, 2010 11:29 AM #1guys pls advice naman po regarding my horn...na test ko naman po ung horn direct sa battery at gumagana but the problem is ayaw kapag pinidot ko sa manibela..some electrician says na baka sa adaptor daw may problema at ung iba naman baka wala daw contact at gamitan ko daw ng liha ung manibela..please..please help me po.
July 15th, 2010 11:34 AM #2
Why don't you do what the electricians suggest? The horn obviously works, so it's a problem in the wiring or the switch. The easiest thing to do at this point would be to sandpaper the contacts, as the guy suggests.
- Jul 2010
- 28
July 15th, 2010 11:52 AM #3ok sir ty po sa advice...ill just remove first the steering wheel this saturday..may pasok kasi eh.
- Jul 2010
- 28
July 15th, 2010 01:51 PM #5owner type jeep po...4K engine po at wala pong air bag ung steering wheel ko sir.help me naman po para i DIY ko nlng po sa bahay.
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
