Results 1 to 12 of 12
    Feb 2004
    hi!
    ket ganun mga sir, nangangamoy gulong habang drive ako. bagon palit yng 4 na tires ko, dati nman nde ganun e.
    asn kya ang problem n2?
    many tnx,
    butchokuy!
    might be the breaks....
    clutch...hmmm.....
    butchokuy, please refrain from using "text-speak" in the boards. thanks.
    Ganun talaga, give time for the gasses to leak out.
    Apr 2004
    okey lang yun, kasi bago gulong mo, masama kung bago paint car mo amoy gulong pa rin (joke)
    Like Sir Glenn says, check break or clutch (lining)
    Feb 2004
    pajerokids: thanks for the reminder.
    actually, it only happened after i change all my tires. dati naman hinde ganun.
    usually, i smell it after ng mabilis kung takbo.
    i use bridgestone 185/70/R13.
    Feb 2004
    btw, hinde ba delikado to?
    di kaya hilaw ang pagkaluto ng tyres?
    i remember isa yan sa mga sinabi sa amin sa factory ng tyres (forget ko na ano factory yung pinuntahan namin nung field trip nung college 18 years ago!) pag sobra daw malakas ang amoy ng goma malamang hilaw. remember binu-vulcanize ang rubber (meaning heat curing) during manufacture. pag mababa ang temperature ng curing hilaw yan, madaling mapunit at pwede ma-strip ang tyres mo pag tumatakbo ka ng mabilis. kung ako sa iyo isauli ko yan sa dealer.
    Dec 2003
    Hindi kaya the tires are bigger than the old ones? Kaya nag rub sa fender? Pero I think siguro baka clutch or brakes kasi yung 2 ang malalakas ang amoy.
    Ask a lady to help you pinpoint where the smell is coming from, I find their noses better than mine. I normally ask my mom, girlfriend, girl na friend or wife to help me pinpoint problems like this.
    Jun 2004
    paglagilaging may amoy madalas rear drum brake napatid or natangnal yung spring, clutch pag hard driving..
    amoy gulong daw ang amoy, so amoy rubber.
    iba naman ang amoy ng clutch o brake pad e.
    my thoughts exactly. Theory lang guys, when the tyres were used, they heated up and some 'curing' of the chemicals used to make the tyre probably occured. This should disappear after a week.
    Feb 2004
    tama ka yebo, iba ang amoy ng clutch at brake pad.
    at ska nangyari lang eto nun nagpalit ako ng mga tires.
    sana nga tama ka pajerokid! i am still observing it.
amoy gulong!
