Results 1 to 4 of 4
- Jan 1970
- 47
June 11th, 2004 05:46 PM #1Mga tsikot gurus, ano po ba ang proper timing ng toyota corolla 2e engine, 1.3ltr?
Dalawa kasi ang suki kong mekaniko, sabi nung isa dapat 20deg,
sabi naman nung isa ay hangang 12 deg, lang... which of them is right?
And the timing setting is it really calibrated in degrees?
salamat po mga peeps... :-)
- Jul 2012
- 3
July 25th, 2012 01:47 PM #3just joined. just saw your query... Rev it to 2000 RPM-timing should show O deg at this point when checked with light.
Advance it a bit if you want slightly quicker resp. for city, "pulling out of the corner" type driving. Retard it a bit if you want better performance at higher RPM's. Hope I was able to help.
July 25th, 2012 11:22 PM #4
Is the AC based cooling in the BYDs unlike teslas that could do both simultaneously or is the AC...
BYD Seagull
