Results 1 to 11 of 11
    Aug 2004
    Guys, may problema ako...recently bumili ako ng bagong front wheel tire tapos nagpa wheel alignment na rin ako sa malapit na shop sa amin...pagkatapos nun hindi na maganda ang takbo ng honda ko...nakakahilo na kapag nakasakay ka...hindi na smooth ang takboparang madaming extra movements...ano kaya ang nangyari? meron ba sa inyo ang nagkaroon na ng ganoong problema? what would you recommend?...nakakahilo talaga ang ride unlike before na very smooth ....
    Aug 2004
    i think the problem is they probably use the wrong specs for your car or they forgot to tighten the nuts. go to a reputable wheel alignment shop.
    fyi the proper way of aligning a car is start at the back and go to front.
    paanong nakaka-hilo? up-down ba yung kotse?
    Aug 2004
    yup up-down yung kotse at madaming extra movement nung una akala ko ndi lang pantay yung kalye..pero ever since nahihilo na yung mga sumasakay sa akin pati ako
    chances are, merong maluwang sa mga ginalaw, suspetcha ko wheel nuts or baka mali yung setting ng tie rods (a long shot, but you might as well check it na rin. )
    kung maluwag na wheel nut yan... may maririnig kang lagutok from time to time from your wheels.
    pwede rin namang sablay talaga ang alignment. computerized ba ang alignment? or mano mano?
    baka nga sablay ang alignment?
    saan mo napagawa?
    try mo kay speedyfix sa shaw blvd,
    ang naka SIR ata dito sa tsikot eh si speedyfix at chieffy..
    Aug 2004
    computerized naman yung wheel alignment...ang finding nga eh hindi aligned yung dalawang gulong sa likod, kaya inadjust pa nya
    Better have it balanced again from another shop, baka di na accurate yung balancer nila. Then try dismount it from the machine at make another test to be sure.
    Aug 2004
    check mo yung tie rod baka inde pantay measure mo ng metro mula 1st thread to nut
    could it be the tires? baka oblong or defective?
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
honda SIR problem
