Results 1 to 18 of 18
    Apr 2010
    good day mga bosing, ano po problema ng clutch system ng sentra FE ko kasi matigas sya apakan at parang may sumasalat pag ipapasok sa 2nd gear? meron din pong shock shift pag bitaw ng accelarator pedal hindi po sya smooth shifting. sabi po ng tito ko baka daw di genuine parts yung nilagay sa clutch parts kaya daw matigas, any advice po mga sir? ano po dapat palitan or iadjust? or need lang po ba ng lubricant? sentra Fe po yung oto at nakuha ko lang po 2nd hand, thanks
    The hard clutch pedal could be sign that the clutch cable needs to be either lubricated or replaced. Also possible the cable used was a "replacement" cable.
    The jerky clutch might mean the clutch needs to be broken in (break-in for a few hundred kilometers) for smoother engagement.
    Apr 2010
    thank you sir, i will try to put some greasing or lubrication to the cable clutch but do you think sir there is nothing wrong inside the clutch assembly? like release bearing or pressure plate to make it more lighter? by the way sir, is it ok to put singer oil for the cable?
    paps after some greasing or lubrication check mo yong pagkakalagay ng clutch cable dapat di nakaipit or masyadong liko, dapat malaya syang makakagalaw kasi minsan nangyari yan sa akin after ko magpalit tinalian ko ng plastic tie wrap yon ang tigas apakan ng clutch ko nong tinangal ko yong tie wrap tapos inayos ko yong pakakabend nya lumambot na clutch ko. sana makatulong..
    Jun 2009
    Is the Sentra FE cable type? Better check, I understand this is hydraulic type.
    Apr 2010
    Quote Originally Posted by Jakk View Post
    thanks sir, subukan kong kalasin yung cable baka nga na bent yung wire nya kasi pag inaapakan ko may tumutunog mismo sa cable parang di sya free. parang na twitwist. hope yun nga ang cause. di ko pa kasi maalis kasi nagamit ko pa yung oto. will get you an update pag na greasan ko na at naibalik, thanks again
    Apr 2010
    Quote Originally Posted by nickriingen View Post
    sir, mine is cable type clutch, 98 mdl. I think 98 and 99 mdls are cable type. 2000 up are the hydro type. or im not sure what year mdls are the hydro type
    Apr 2010
    mga bosing, ok na clutch pedal ko ang lambot na, what I did is to disconnect the entire cable from the pedal. ang hirap lang umilalim sa floor, ang hirap matanggal yung cable unless alisin yung buong pedal, napansin ko na tuyong tuyo yung grease ng cable kahit hilahin ko ang tigas gumalaw. then i put some wd40 until mag flow sya from top to bottom holding the cable vertically then try koi push and pull until I notice na madali ng hilahin back and forth. so nung binalik ko na, ang lambot na ng pedal parang naka hydro hehe. thanks po sa mga advice nyo. akala ko release bearing na or clutch plate na, thank you again and more power to all
    paps sarap ng feeling kapag naayos mo problema ng kotse mo na kaw ang gumawa di ba?:barmy: :barmy::barmy:hehehe.
    Dec 2009
    I like! hehehe!~
    Apr 2010
    tama sir, sarap din feeling sa bulsa menus labor hehe. sana mekaniko nalang kinuha kong curso hehe
    Quote Originally Posted by raycor View Post
    WD40 is only a temporary fix. It will soon dry up in a few days. You will need to use an oil that will not evaporate or dry up quickly.
    Aug 2008
    tama si ghosthunter. mangyayari nyan every now and then mo kakalasin yung cable para lagyan ng wd40. try mo yung mga "singer" brand na pang makina, this should last a little bit longer. i also tried squeezing in grease through the small openings on the ends of the cable sleeve before, it worked fine with my FE until the day i sold it.
    Apr 2010
    sir napapansin ko nga medyo tumitigas nanaman yung clutch ko. grasa ata talaga ang nilalagay kaso ang hirap naman lagyan from end to end. try ko nalang uli singer oil kahiti disconnect ko nalang yung isang end sa engine siguro at dun ko nalang patuluin ng oil.
    Apr 2010
    same prob sa sentra series 3 namin ang tagal ko na pinagtyatyagaan to ill try to go sa mechaniko bkas to have it greased hopefully umayos..may effort talaga kasi yung clutch pag inapakan..i would like to try some sentras here in lp to see kng matigas din clutch nila..sana po may tumulong
    Nov 2007
    what could be the problem naman po
    mataas ang clutch 3/4 ang taas.. nakakangalay na
    kapalit lang ng clutch disk
    * jansky, meron pong stopper screw sa pedal ng clutch don po adjust yong angle ng clutch then adjust nyo na po pati tension.:cheers2:
    Jun 2010
    mine hydraulic din 99 model, alam ko pare pareho lahat ang fe hydrulic or fluid type
clutch problem on sentra FE
