Results 1 to 15 of 15
    Aug 2009
    Hi Nissan Urvan owners and users, ano po ang mga modification nyo sa rear aircon ng urvan kasi kahit malakas ang aircon e kapag tirik po ang araw ay nag reklamo ang passenger sa last row na di daw nakaabot ang lamig sa last row. Appreciate if you can share your modification on your rear AC.
    On a unit that was for rent, there was another blower in the middle row, like an electric fan.
    What the MB100 guys do is put in another evaporator, usually from a Starex. On the Urvan, you can probably hang it from the luggage compartment then firing forward.
    Check the Ssangyong section of our forum for photos.
    Jun 2011
    sir otep... sa mb po 17C ANg compressor good for 3 evaporator talaga....
    baka iba po ang compressor ng urvan... at hindi kakayanin ng compressor ng urvan ang additional evaporator... pwede kung blower lang...
    send ko sayo tom. pictures ng additional blower sa urvan... if you have time post mo po....
    Aug 2009
    Ang plan ko po ay maglagay ng ducting para equally distributed ang hangin to each passenger sets.
    Jun 2011
    Quote Originally Posted by dongmbb View Post
    kung 17C ang compressor ng URVAN or kung kaya ng compressor mo nang 3 EVaporator at 2 condenser... install ka lang ng additional evaporator sa gitna sigurado malamig na yan...
    another problem mo po pag nag dagdag kayo ng evaporator kung kaya naman ng alternator nyo po ang additional na load... may dagdag na 2 evaporator blower motor yan then isa pang additional AUX FAN ulit....
    individual ducting mukhang pahirapan po ata sa pag convert nyan...
    Tsikoteer akosijhepoi sells alternators. Baka po maka mura tayo. Hehe.
    Napost ko po sa Ssangyong forums yung pic ni sir glenn sa mb niya. Hehe
    Before venturing into A/C modifications: How old is the van and how long has this been the complaint (since brand new)? A/C is serviced regularly? Do you have good tint to improve heat rejection or just the crappy CASA tint? In the case of our office Urvan, the tint was changed and it helped the A/C performance noticeably. A lot of the UV vans also use dark shades of tint.
    Aug 2009
    The performance of the AC is same as brand new for a 2.5 years old van, but if loaded with 12 pax during noon time the passenger at the back was complaining for the AC. What kind of AC regular service you mean? I will try to use dark shades because my current tint not so dark.
    Jun 2011
    yung iba nag add sila ng evaporator fan sa gitna.... tinangal lang yung evaporator... yung housing at fan lang nakakabit....
    may nasakyan ako dati Urvan na pamasada... tanghaling tapat more or less 10 kaming sakay nasa likod ako... tama lang ang lamig.... hindi naman maiinit
    ^The A/C has been cleaned already anytime recently? You can try starting there and also ask the shop what can be done to improve the cooling further. Over time pag madumi na yung evaporator and condenser, performance will deteriorate. Adding a better tint with good heat rejection can help.
    Jun 2011
    ang a.c. ng urvan malamig naman wag lang over loaded....
    seating capacity lang dapat... 12 including driver... kaso nga lang pag dating talaga sa likod hindi na inaabot ang mga naka sakay sa likod at sinolo na ng nasa 2nd and 3rd row ang a.c....
    mag add nalang sila ng addl. evaporator fan sa gitna... ayan ang napansin ko na ginagawa ng lahat ng pumapasada medyo hindi nga lang maganda tingnan... pero ang imptortante hindi naman mainit....
    Aug 2009
    Cleaning and pull down of AC evaporator for 2.5 years old Urvan is not advisable, because there is possible refrigerant gas leaking on fittings after a couple of period of re-installation of the system. The ideal is to frequently clean the front and rear AC fan blower to eliminate dust coming in into the evaporator fins.
    Shouldn't the rubber o-rings be replaced as well during A/C cleaning? When you don't, on any car, chances are it will leak indeed (happened to me several times). I agree that keeping the "environment" of the A/C clean from dust does go a long way in preventing dirt build up; also choosing where you park as leaves are usually a culprit in contaminating the A/C system as well.
    - - - Updated - - -
Nissan Urvan Airconditioned System
