mga bosing, na try nyo na po ba nag pa overhaul cleaning ng injectors? ano po mga causes kung bakit ino overhaul ito? isang mekaniko dito samin nagsabi na titipid daw sa gas pag nalinisan, di po ba complicated ito and i think may numerical order pa ang pagkalas sa mga ito? at saka nangangamoy gas pagka off ng oto but no signs of leak naman. any input would be very appreciated, thanks
Kapapalit ko lang ng fuel injector. Sa makina ko 10 to 14 ohms ang resistance nito , DIY lang ginawa ko at ngayon ayos na idling ng makina. May nakausap ako naghahanap siya ng complete set ng injector para sa GA16de niya nalinisan o na overhaul na raw iyong 4 na injector niya kaya lang may problema pa rin sa andar ng makina niya . Kung maayos naman ang sasakyan mo huwag mo ng pagalaw iyong fuel injector mahirap humanap ng brang new para sa Nissan at walang stock. Iyong nangangamoy na gas pag off mo ng sasakyan tignan mo iyong fuel hose mo na nakakabit sa injector papunta fuel filter baka malambot na iyong hose at may singaw . Ganyan din nangyari sa akin at nakita ko may mallit na leak sa hose pag hinawakan mo dahil malambot na iyong hose o sa hose clamp baka maluwag.
the injectors were not designed to be "overhauled". there are only a few basic parts inside: pintle, spring, electromagnetic coil and the housing. you can only clean it and there are no user serviceable parts inside. if they told you they "overhauled" it, you paid for services that were not done nor possibly done with damage. the only maintenance you can do are: replace o-rings, grommet and cleaning. as with cleaning, harsh solvents are prone to melting the insulation coating in the magnet wire of the coil causing them to short out or drop in resistance or lose magnetic strength
