gauge panel cover P500
side mirror covers P300 each
ignition key assembly P1800
grill emblem P500
battery plate-p1000
Stock bumper front and rear 1500 each
Flywheel 2500
Side glass 1500 4pcs
intake manifold P 1,200
gas tank assembly P 4000
DOOR PANEL / DOOR SIDING-p1,200 each
aircon compressor P3,500
Sentra B13 ECCS 60/40 Rearseat Assembly -p2,000
bare cylinder head P 3500
oem exhaust manifold with heat shield P 1,800
valve spring and retainers P 1500
cam shaft w/ gears intake, exhaust P 1500
hazard switch P500
handbrake p1,000
camshaft bearing caps intake, exhaust P 1500
lifter valve or piso P 1,500
oem high tension wire P1000
starter 2,500
automatic transmission P12,000
harness-5000
valve intake,
exhaust P 1500
trunk rubber P800
clearance light-p650
dome light -p400
Timing chainwith tensioner 1500
auxiliary fan 800 each
Windshield Front 2000/Rear 2000
Steering wheel Assembly 1500
Stock bumper front and rear 1200 each
spring 800 each
Rear Pillar Garnish 500 each
Front Pillar Garnish 500 each
Step Sill (front) 500 2 pieces
Back board 500
Brake pedal p800
Clutch pedal p800
