Results 1 to 18 of 18
    May 2008
    I just bought a second hand ECCS.
    ok naman nung test driving but when we left..about 30mins driving. Bigla tumirik. after a while pwede uli mag-start tapos titirik uli. Ilang beses tumirik. Ano po kaya diperensiya. Does it need engine overhaul?
    pls help!
    May 2007
    Quote Originally Posted by Dude7 View Post
    pls help!
    Not much of an information, anyway, your problem could have been anything like, clogged fuel filter, weak fuel pump, restricted fuel line or bad relay. Replace the the fuel filter first this could be the culprit and have somebody listen to your fuel pump if kicks in, (short humming to prime the system).
    May 2008
    Quote Originally Posted by v6dreamer View Post
    Thanks! I'm not that good in cars, but all possible solutions posted are very much appreciated. Ipinapalitan ko nga fuel filter.
    Some nearby mechanics suggested na kailangan ng engine na ma-overhaul. Meron po ba kayong maisa-suggest na nissan ECCS expert around Paranaque area.
    Thanks a lot!
    bro, bring it sa Nissan Casa for diagnosis. mura lang naman pa-diagnose. they will connect an engine analyzer para malaman kung ano talaga sira ng car mo. mahirap kasi ang trial and error na trouble shooting. good luck.
    I agree with blacksun. Bring it na lang sa Casa. Or if hindi ka naman nagmamadali at gusto makatipid muna, try visiting the forums of www.nissanbayan.com. A lot of people can probably help you there....or at the very least suggest a shop that they trust in your area.
    May 2007
    [quote=Dude7;1082315]Thanks! I'm not that good in cars, but all possible solutions posted are very much appreciated. Ipinapalitan ko nga fuel filter.
    Thanks a lot![/quote
    How did he conclude that engine need overhaul? Engine runs good except that it's stop like it cut off gas. Fired that man.
    You have change the fuel filter. Is the car behave the same way?
    May 2008
    [quote=v6dreamer;1082364]
    Yup, the mechanic has changed the fuel filter. inoverhaul radiator.
    Umandar na uli. Pero namamatay matay engine. Ang latest findings e sa electronic box daw. Baka daw wiring. BUkas ay dadalhin sa especialist para check electronic box.
    Thanks sa mga suggestions. Btw, may recommended especialist ba kayo? Magkano kaya ang gagastusin ko pa dito. Salamat na marami.
    May 2008
    Hi!
    Maganda na takbo ng ECCS ko. Pero after a while ay namamatay makina.
    Na-diagnosed na ng nissan especialist at ang findings daw e electronic box. Mga 8T daw ang repair at kung papalitan daw ng bago ay 40T.
    Pls suggest...yun na nga ba talaga sira nun? parang hindi pa rin sila sigurado..iwan lang daw muna yung car sa casa.
    Thanks for all the posts.
    Aug 2004
    A capacitor alone shouldn't cost much... but I don't know how many electric experts are familiar with Nissan boxes. Reportedly, there are guys who can fix Honda boxes, but I'm not sure. Best bet, really, is to replace the box entirely.
    But also check your wiring... there could be a short there somewhere that is causing the electronics to overheat.
    May 2008
    thanks sa lahat.
    Thanks Niky!
    Ayos na car ko. Inayos lang wiring ng computer box. Pinalitan din yung coolant temperature sensor at mga filters.
    Ayos na ayos ang takbo. hoping na tumagal pa ito.
    more POWER to all tsikoters!!!
    Oct 2008
    hello DUDE7,
    i have same problem namamatayan din ako, baka wiring din ng computer box ko saka ayon sa mekaniko need to replace my temp coolant sensor kasi kapag nakakabit bumababa idling saan ka nagpagawa ng wiring at replace ng sensor at magkano nagastos mo....
    thanks,
    thanks sa lahat.
    Thanks Niky!
    sir, i think we have the same problem, same po ung car natin, 2mirik din me ng mga twice na ata.. how much po ba yung cost ng wiring ng computerbox mo? tingin ko pareho tlg ng problem ng car ko eh... tnx..
    Aug 2008
    gud nun.ung fuel filter mo at d back sa ilalim ng upuan mo.papalitan u na.wla problema sa engine.
    Oct 2008
    thanks sa lahat, so far yung sa akin medyo okay na pinalitan ng high tension wire 1 set nagagamit ko na rin aircon ko. hopefully tuloy tuloy na ito..
    Sep 2008
    Quote Originally Posted by handler View Post
    up ko lang ito ulit having same problem. sir san mo pinacheck ung computer box ng eccs mo? tnx.
    hey there,
    ok n b eccs mo? san mo pinacheck. if anything else happens and di n kinaya nung mechanic mo email me. I'm connected sa dealer sa alabang.
    njgarin*gmail.com
Nissan ECCS Engine Problem. Pls Help
