Results 1 to 19 of 19
    May 2018
    Good day Sirs
    Just want to ask for some suggestions for shops who has expertise for Nissan X-trail.
    We have T30 06', main concern is acceleration. RPM's abnormal like jerking even though stable ang tapak sa gas pedal. Situation is when traveling 0-40km/h, 40 up smooth na. Imagine ni-yuyugyog ka habang umaandar.
    Our unit's well maintained- change oil, spark plugs, filters etc. Thinking of transmission problem?
    Hope you can suggest shops whose expert overall with Nissan X-trail, preferably from south.
    Thanks!
    Quote Originally Posted by mikezzz View Post
    Good day Sirs
    Thanks!
    change oil? does that include the fluid in the transmission?
    May 2018
    Yes Sir. Transmission fluid's also done.
    when was the last transmission fluid changed?
    does the engine idle ok?
    May 2018
    Last change was few weeks ago, tho it was the first time changing it after reaching 105k kms. Service advisor (goodyear servitek) detected burnt smell that’s why he had it changed - which solved another problem - engine shutdown during inclined position (not sure tho if connected) but yeah engine doesn’t shuts down anymore.
    I think engine idle is okay. Stays around 900-1000 rpm at idle state.
    Just to add info, tried scanning it with OBD2 but no problems detected.
    Thanks sir for the notice.
    I know the transmission fluid was changed recently, my question was when was the transmission fluid changed prior?
    the transmission fluid needs changing every 24mo as per service booklet.
    Jan 2008
    Good day Sirs
    Thanks!
    Possible transmission.. did you scan for ecu errors? Pwede din faulty na yung ignition coils... or bad injector..
    May 2018
    Oh sorry sir, my bad. Not really sure if it was changed before since it was bought 2nd hand. Will check it..
    Yes sir already scanned. no error was found. will check on those 2 points.
    Thanks sir!
Nissan X-trail - Expert shops outside CASA
