Results 1 to 10 of 11
- Dec 2007
- 186
May 9th, 2017 11:58 AM #1Hello NAV World! May I post some essential part # for this model which might be of use later in your PM days... i will update this from time to time...
airfilter airconditioner --- 272774JA0A
oil filter --- 15208EB70C
air cleaner element --- 165464KV0A
cartridge assembly fuel filter --- 164034KV0A
fan & alternator belt --- 117205X00A
power steering/oil pump belt --- 117205X00A
auto tensioner assembly --- 119555X00E
idler pulley assembly --- 11925ED320
disc pad front brake --- D10604JA0A
brake shoe set rear --- D40604JA0A
lower arm assembly RH --- 545004JA0A
lower arm assembly LH --- 545014JA0A
upper arm assembly RH --- 545244JA0A
upper arm assembly LH --- 545254JA0A
stabilizer link RH --- 546184JA0A
stabilizer link LH --- 546684JA0A
- May 2008
- 137
May 9th, 2017 08:01 PM #2Maidagdag ko na rin 'to sir. I also posted this in the NP300 NAVARA thread.
Owners/Users and Service/Repair Manual for NP300 Navara 2015 to present
NP3 Series (2 15 - Present) - navlife | navlife stickers and more for Nissan Navara
- Dec 2007
- 186
May 9th, 2017 09:10 PM #3a BIG favor you gave to the navara folks. these are actually indespensable resources when you start running out of warranty and you chose to do your own part sourcing and choosing your own repair shop in the long term for routine preventive maintenance. And this is very true to the SFCP world. mababa ang cost of maintenance mga sasakyan namin sa club dahil well documented ang santa fe (service manuals) and the right parts are easy to find when you have the correct part numbers.
I will try to post for some variances in part numbers with the 4x4 but most consumables will be the same.
- May 2008
- 137
May 10th, 2017 04:44 PM #4
- Dec 2007
- 186
June 18th, 2017 08:20 PM #5i will add some more...
OIL COOLER ASSY ---213055X00A
THERMOSTAT ASSY --- 21200BN301
ENGINE COOLANT TEMPERATURE SENSOR ---2263044B20
PUMP KIT-WATER ---B10105X00D
GASKET-WATER PUMP --- 21014EB70A
HOSE-RADIATOR,UPPER ---215014JN0A
HOSE-RADIATOR,LOWER ---215034JN0A
RADIATOR ASSY ---214604JM0A
CAP ASSY-RADIATOR ---21430D999A
MOUNTING-RUBBER,RADIATOR ---21508EB70A
INSULATOR-ENGINE MOUNTING,FRONT ---11220EB70C
INSULATOR-ENGINE MOUNTING,REAR ---113204JL0A
GENERATOR (alternator) --- 231004KV0A
MOTOR ASSY-STARTER ---233004KV0A
BLANK ENGINE CONTROL MODULE (ECU)--- 237104KV2E
August 21st, 2019 06:41 AM #6
- Jun 2017
- 7
June 24th, 2017 12:10 AM #7
- Dec 2007
- 186
June 25th, 2017 12:30 AM #8
June 25th, 2017 12:42 AM #9
nice part numbers... are the parts locally available? is there a price book for these items?
which shops(non casa) offer installation of these items?
- Dec 2007
- 186
they did mention that the Seal would have won a 0-60 comparison. But I agree that a 60-80 test...
(11th Gen) Honda Civic
