Results 1 to 11 of 11
    Aug 2012
    please advise me what to do with my clogged 3 injectors. is there any remedies in de clogging this things. are there any shops who specialise in cleaning these. please help po mga bossing......
    try mo tuktukin sa labas ng injector gamit ang handle ng screw driver. check mo rin muna fuel filter baka dun lang nasasakal fuel tapos akala mo clogged injector na.
    Aug 2012
    fuel filter had been changed with a new one and check the fuel line after filter, the supply is ok. magkano po kaya surplus nito and where in banaue i can buy a good stuff. any advice are really appreciated. series 3 master please help.....
    Nov 2004
    sir, opinion ko lang, sa tagal na ng series 3, hindi worth i declog, at malamang baka lumaki lang ang butas ng injector, lalo ka pa lumakas sa konsumo. palagay ko, best option lang ay bumili ka ng 4 pcs na na bago. di ko alam kung may replacement ito. kapag kumuha ka rin ng surplus, ewan ko lang kung match ito sa local specs. kadalasan yata, 1.5 liter yung nakikita kong mga surplus motors dati (dati yun, ewan ko sa ngayon).
    Jun 2005
    baka makatulong... bumili ako surplus fuel injector ng sr20 2 years ago. 800 per piece.
    Nov 2004
    sir, common lang sa series 3 ang injector para sa sr20 ? nasubukan mo na ?
    Aug 2004
    SR20 injectors are way too big for the GA.
    You can have old injectors ultrasonically cleaned, but the expense is almost as bad as buying a secondhand set. Makes more sense to just replace the bad ones.
    If i recall correctly, Servitek Alabang can service clogged injectors.
    Jun 2005
    Quote Originally Posted by NisToy View Post
    bro, di sila common. 2liter engine yung sr20 eh.
    reason kung bakit ko sinabi yun is to give you an idea kung magkano price ng surplus fuel injectors ng nissan. dami nyan sa evangelista at banawe surplusan...
    Nov 2004
    ok sir, ty at pasensya na. baka lang kako common. ty uli
    Aug 2012
    na declogged ko na mga bossing un injectors ko. binabad ko ng 24 hours sa acetone solution. its only some dirts. sa banawe po mga bossing ay 3k po isang set ng injectors s2 surplus but if per piece po ay ik ea. ty po sa mga advice ninyo,
series 3 clogged fuel injector
