Results 1 to 8 of 8
    Apr 2010
    Sir Patulong naman po kung anu-ano po periodic maintenance ng escapade
    Change oil = every?
    Change OIl Filter= every?
    Change V-belts = every?
    Change timing chain = every?
    kung may nakalimutan po ako pakilagay na lang po.
    2nd hand po escapade namin 64000km na po takbo niya model 2004.
    saka para saan po yung knob na nasa lower portion po ng driver seat na pag inikot po ng clockwise tumataas idle ng engine?
    thank you po in advance.
    Sep 2009
    Quote Originally Posted by ron197904 View Post
    Change oil = every?
    Ron maybe I can help kasi I had my urvan used abusely for 8 years, pero until now ok pa naman siya though had sold it already, change your oil ever 5000 kms or less, isabay mo na syempre pati oil filter, yung V belts since kabibili mo pa lang unit mo palitan mo na din since di mo alam kung kelan pinalitan previous owner afterwards 50k kms ang dapat next na pagpapalit nyan, timing gear ang engine nyan so no chain to replace, pati ung mga lubricants like transmission and diffrential gear oil palitan mo na din about 3 liters lang naman yan sa diff and tranny, pati yung atf ng power steering papalitan mo na din make sure na ma drain and bleed ung steering system, yung brake fluid ipa bleed para mapalitan na din ng bago kasi pag maiitim na sisirain ang master cylinder,ung front wheel bearing ipa repack mo na din both wheel, pati ung master ng clutch ipableed mo na din, pati nga pala air cleaner filter mo palitan mo na din kasukat ng pang L300 yan less than 200 pesos lang yan,ipalinis mo na din pati brake system mo, ung sinasabi mong knob sa minor yan pwede mong taasan o babaan pag sobra baba may tendency na magvibrate engine mo,kung may extra ka pa pati yung air con ipalinis mo na din to protect condenser mo pag makapal na dumi baka mabutas yan mas malaki gastos,mahusay na van yang escapade basta tama lang sa maintenance....sna nakatulong ako
    Apr 2010
    Quote Originally Posted by pajeri20 View Post
    Sir maraming salamat po... mas ok po ba ipagawa ko ito sa service center ng nissan o sa trusted mechanic ko? thanks again...
    Feb 2005
    Kung may kakilala ka na mechanic na magaling don mo na lang pagawa. Masyado malaki magastos mo kapag nag-casa ka pa. Wala na warranty yan di ba? Kami after ng warranty sa labas na rin nagpapagawa.
    Mga sir san nga plang casa ng Nissan pwede magdala ng oil at oil filter during PMS? Under warranty pa kasi Urvan namin sabi ba naman sa Nissan Shaw ma void daw warranty kapag di sa kanila kinuha ang piyesa. Bad trip doble gastos tuloy kami. Buti pa sa Mitsubishi pwedeng magdala ng oil.
    Apr 2010
    salamat sa reply sir... anu maganda brand na oil gamitin.. thanks uli mga sir..
    Sep 2009
    I agree with likot kung may trusted mechanic ka ok un at saka kung magaling talaga mechanic mo alam niya magiging history ng urvan mo regarding maintenance matters, petron ung last na ginamit ko sa urvan ko nun basta look for the rating mas mataas ap rating niya the better,basta regular lang change oil bago mag 5k or 4k lang lalo nat puro city driving kasi sa traffic tuloy andar ng engine pero mababa ang mileage, saka pala iadd ko never na gamitan mo ng flushing liquid yung radiator mo flush mo lang ng tap water pag malinaw na drain uli saka mo lagyan ng coolant, ung sa kin nun ginamitan ko nagkaleak ang radiator dun nag start sakit ng ulo ko kaya pinalitan ko na lang radiator, grabe mahal ng orig nissan parts....
    Fuel Filter every 20,000kms
    Oil Filter every 5,000kms
    Air Filter (if you're using original), air clean every 5,000kms then change every 20,000kms
    Adjust valve tappets every 20,000kms
    change gear, differential, PS, coolant, etc. every 40,000kms at the most.
    On Nissan OEM parts being expensive. Per my experience, they last really long and its not too far off from Toyota and Honda really. On the filters, if the OEM is pricey, just use the VIC brand.
    On the warranty, do talk to other dealers. I used to bring in my own parts (fluids) and just buy my OEM filters from them and there wasnt any issue to warranty.
    Oct 2007
    ung skin ang gmit ko fully synthetic top1
Urvan Escapade Periodic Maintenance
