Tanong ko lang po meron po ba weber carb na compatible sa 89 sentra ko. ang engine ko is 1.3 sohc.
bakit? pang karera? sayang lang pera mo diyan. kahit gaano mo kargahan di rin gaano lalakas makina niyan.
Palitan mo nalang ng makina yan ... ;)
Wag mona pagtiisan 1.3L Carb(?) mo.
You could use DC40E dual Webers, but that's overkill if you're not going to race.
More practical is a cheap brand new replacement Toyota 4K carburetor.
Tinitignan ko kasi ito weber 32/36 DGEV i don't intend to race naman, just reading that it offers better mileage and added power and mukhang time to change na yung carb ko, yung engine ko parang running rich na kahit ano adjust na sa carb, amoy gas na yung exhaust ko tapos pugak pugak na sa idle kailangan ko na bigyan bigyan ng gas para di mamatay. was just thinking rather than going oem again with the same power would rather have an upgrade na lang.
if you have a budget then go for the weber. i've heard maganda ang response nya sa low to high end power.
ako rin parang gusto ko magpalit ng carb ksi amoy gas na rin ang exhaust ko.
ride is a nissan sunny pick up 1200cc engine.
the question is kung meron weber carb na compatible sa sentra 89, yes meron.
bolt on? wala. you can use weber carb convertion kit (SKU Number: 1JA 538073) with minor modification...
if the question is, is it advisable? please check and consider all the above posts...
Likewise, as far as I know, weber carb for sentra is being used for 1.6 engine and not for 1.3... my cent
weber is really FTW... the only downside as far as i know is its price...
i once used it to my old corona. aside from its stability and response fluidness, no headache in my carb sytem since then...
sir Niky, paano yun adapter? Ako lang kasi ang magkakabit. Nagtanong-tanong din ako sa iba, di nila alam. Papasadya ba ako o meron ng nabibili para isalpak ko na lang sana. Meron kasi akong nakita sa Sulit.com, for sale na "brand new" 4k carb = P2,900 or P3,500 w/ adapter.
It's just a plate that will match the carb to your intake manifold. Can't recall what mine looks like. Had it installed a long time ago.
