Results 1 to 5 of 5
    Oct 2009
    Good day Nissan users. Newbie po ako and planning to buy 2nd hand car early next year (i prefer 2000-2001 Nissan Exalta). Kaya ngayon palang e gumagawa na ko ng study Tulungan nyo nman ako mag decide kung tama ang decision ko.
    Gusto ko malaman kung magkano maintaince cost nito na nilalaan nyo d2 (on the regular basis ex:change oil cost and others)
    Pati Pros & Cons na rin.
    Marami na rin ako nabasang reviews dito. Sana po meron makapag share ng updates lalo na sa mga new users.
    Thanks
    Oct 2009
    up lang po
    Hi Im also new here. I don't own an exalta but my father in law owns a n16 model (2005 sentra series). All I could share to you is that every 5,000 kms or so (cguro mga 1 and 1/2 to 2 months na everyday na gamit) he pays about 6-10k for regular maintenance sa casa... sometimes meron mga parts na nirereplace but im not really particular with it... there was also a time na umabot ng 1 week ung gawa sa casa and he paid 23k for it... I asked kung anu ung pinalitan na parts pero di ko naintindihan ung pinagsasasabi nung contact nya... something sa engine daw... pero nung ni drive ko ung sentra e parang brand new ulet ung takbo... as in sobrang tahimik nung makina.. smooth tlga and malambot lahat... steering, transmission, brakes, everything... be ready sa gastos pag gusto mo magkakotse kase its like having a child.
    I do know basic maintenance like tire pressure, checking for leaks... mostly mga you can do it yourself if you have time... like oil change mura lang ung mga ganun.
    I like the sentra series... its mandatory to know that an older car it is the more maintenance it needs. So kung 2010 ka bibili ng car its better when you can afford a newer car ung mga 2004-05 up model na. But your choice of 2001 model isn't bad. I know this from experience cause for a while i've driven all sorts of models, old and new. Iba na tlga ung mga 2000 and up na mga kotse ngaun.
    Kung bibili ka ng second hand na kotse mas maganda pa change oil mo na agad .
    kung automatic transmission palitan na rin ng ATF fluid para mas maganda ang shifting , Change sparkplug , Air filter, Fuel filter, oil filter . Check mo rin brakefluid level at Brake pads kung worn out na. Pa check mo rin ang engine timing ayon sa spec ng makina para mas matipid sa gasolina . Check all hose for leak radiator hose, powersteering hose.
    Oct 2009
    Meron ba signs na masisira na ang transmission, i heard na mahal daw to pag nasira. What if pagbili ko e masira agad to
Regular Maintainace Cost for Nissan Exalta
