mga bosing kwestyon lng sa nka h.i.d sa knilang b13..db ung bubog n headlight may groove sa loob..kumbaga hindi sya clear glass di ba?..wla b problem un sa linaw ng h.i.d?..tia
tnx sa reply bro..balak ko sana kc bumili, actually naka 130 watts n ako n yellow bulb..ok naman sya..problem ko lng minsan sa salubungan mejo talo n ung ilaw ko wla pa naman ako tint..kaya silaw lalo n pagmga bus saka jeep..makakatulong b tint para iwas silaw?..
go for osram night breaker. upgrade mo lang muna with relay and ground.
night breaker vs. silverstar video:
http://s34.photobucket.com/albums/d1...t=MVI_5786.flv
HID only looks bright when you look at it. but look at the throw, a stock altis can beat it unless 4300k yung color ng HID.
tnx sa reply bro..san kya mkakabili nito?..plano ko kc 100w all season sa headlight nd nightbreaker sa fog ok b un?..
check mo po sa philips xtreme/osram nightbreaker thread.
http://tsikot.yehey.com/forums/showt...=40777&page=13
mikeleccsat, hi...
ung yellow bulb is good only for fog and harsh weather driving slowly, but on normal weather sabog ung light, maganda lang tignan, but you cant see much, just try a clear bulb, big difference, napansin ko lang yellow bulb shine best in combination of stock color headlight, nagbleblend sila, so use it only on auxillary or foglights. try using 130watts clear bulb... you'll see what i mean. but of course you have to use a relay to maximize the light output... hope this helps
