Results 1 to 3 of 3
    Jul 2010
    new bie here mga boss, I bought this car from a friend ok naman ang performance ng engine pero may problema lang ng konti kasi ang hirap mag sara ng pinto kailangan pa ng force from the outside to close it. and recently nag stockup ang lock ng front pasenger side. sa 3 door lang nag function ang mga door locks pero kahit i mannual o use the remote key ay ayaw na bumukas ng door sa from passenger side. baka naman po may mai advice kayo na maaari kong gawin. baguhan din po ako sa pag gamit ng nissan. thanks and more power.
    Jan 2009
    Check mo kung ok pa ang mga bisagra ng mga pintuan. Pag nakabukas yong pintuan, try mong i-angat baba kung may alog. Kung meron either maluwag yong turnillo, sira yong bisagra, or mis-alligned na (hindi na lapat) possibly caused by an accident. Regarding the front passenger side issue, baka yong door lock mechanism na ang sira mismo. Kasi kung actuator ang sira, dapat kaya pa rin i-lock manually if I'm not mistaken.
    You can also ask your trusted mechanic to check these stuff for you.
    Its a common problem with the Exalta model Sentras. (actuators if i recall correctly). This happens when someone is opening or closing the door while you're still locking/unlocking it.
need help for my nissan exalta gs
