Results 1 to 11 of 11
    Dec 2007
    Hello NAV World! May I post some essential part # for this model which might be of use later in your PM days... i will update this from time to time...
    airfilter airconditioner --- 272774JA0A
    oil filter --- 15208EB70C
    air cleaner element --- 165464KV0A
    cartridge assembly fuel filter --- 164034KV0A
    fan & alternator belt --- 117205X00A
    power steering/oil pump belt --- 117205X00A
    auto tensioner assembly --- 119555X00E
    idler pulley assembly --- 11925ED320
    disc pad front brake --- D10604JA0A
    brake shoe set rear --- D40604JA0A
    lower arm assembly RH --- 545004JA0A
    lower arm assembly LH --- 545014JA0A
    upper arm assembly RH --- 545244JA0A
    upper arm assembly LH --- 545254JA0A
    stabilizer link RH --- 546184JA0A
    stabilizer link LH --- 546684JA0A
    May 2008
    Maidagdag ko na rin 'to sir. I also posted this in the NP300 NAVARA thread.
    Owners/Users and Service/Repair Manual for NP300 Navara 2015 to present
    NP3 Series (215 - Present) - navlife | navlife stickers and more for Nissan Navara
    Dec 2007
    Quote Originally Posted by blacksilver323 View Post
    a BIG favor you gave to the navara folks. these are actually indespensable resources when you start running out of warranty and you chose to do your own part sourcing and choosing your own repair shop in the long term for routine preventive maintenance. And this is very true to the SFCP world. mababa ang cost of maintenance mga sasakyan namin sa club dahil well documented ang santa fe (service manuals) and the right parts are easy to find when you have the correct part numbers.
    I will try to post for some variances in part numbers with the 4x4 but most consumables will be the same.
    May 2008
    Quote Originally Posted by godwhacker View Post
    It's always a pleasure to share and help fellow owners sir. I have also shared service / repair manual for Montero here in Tsikot sourced from Russia naman.
    Dec 2007
    i will add some more...
    OIL COOLER ASSY ---213055X00A
    THERMOSTAT ASSY --- 21200BN301
    ENGINE COOLANT TEMPERATURE SENSOR ---2263044B20
    PUMP KIT-WATER ---B10105X00D
    GASKET-WATER PUMP --- 21014EB70A
    HOSE-RADIATOR,UPPER ---215014JN0A
    HOSE-RADIATOR,LOWER ---215034JN0A
    RADIATOR ASSY ---214604JM0A
    CAP ASSY-RADIATOR ---21430D999A
    MOUNTING-RUBBER,RADIATOR ---21508EB70A
    INSULATOR-ENGINE MOUNTING,FRONT ---11220EB70C
    INSULATOR-ENGINE MOUNTING,REAR ---113204JL0A
    GENERATOR (alternator) --- 231004KV0A
    MOTOR ASSY-STARTER ---233004KV0A
    BLANK ENGINE CONTROL MODULE (ECU)--- 237104KV2E
    Jul 2019
    This helps a lot! Can you post front and rear suspension items too?...pag may time ka sir! Thank you!
    Jun 2017
    It also very helpful kung meron makakapag share ng mga reputable auto parts store para sa mga above items. Thanks
    Dec 2007
    Quote Originally Posted by chowder View Post
    +1
    phone/address - malaking tulong sa mga owners gustong mag PM ng kanilang NP300 for savings.
    nice part numbers... are the parts locally available? is there a price book for these items?
    which shops(non casa) offer installation of these items?
    Dec 2007
    should be available in banawe... but the shops???
    here is an example of online
    but quite costly.
    Jul 2017
    but quite costly.
    Got our 2017 BRILLIANT SILVER NAVARA EL 7AT (2X4) last Friday July 15 ... just waiting for the car registration before going to our 1st long drive. Plan: Manaog
NISSAN NAVARA NP300 7S A/T  2WD PHDM  PART NUMBERS  (YD25DDTi)
