Results 1 to 5 of 5
    May 2008
    mga bro anu ba tlg ang engine ng gts?? may pagkakaiba ba ito sa b14 model?
    It's exactly the same. GA16DE. The GTS is still a B14
    It's the 2000 Exalta B14 that has a different engine. It's a GA16DE with VTC (variable cam timing), but aside from a different head and a reprogrammed ECU, it's still the same engine.
    May 2008
    sir ano po ba ang tamang timing ng gts? ilang deg? at anu ang dapat na sparkplug ang nakalagay?? tnx ....
    5-10 degrees ata ignition advance, can't remember. The right plugs are NGK BKR6E, I believe (checks internet)... BKR6E-11... these are stock fitment and are the best plugs for the engine... you can actually lose power by changing to different tip shapes. If you want fancier plugs, you can get the platinum version of these, but you really don't need to.
    You can ask for more help at nissanbayan.com
    Jun 2006
gts engine?
