Results 1 to 4 of 4
    good day.. hingi lang po ako advice.. yung exalta auto trans kapag nag 2nd gear na sya umiigkas.. medyo malakas yun sipa, pero yung mga susunod na gear smoot n.. pinapalitala ko n ng atf and nilinis na daw yung filter.. 2nd opinion ako sa ibang mekaniko, sabi nya planettary gear cariier daw ang problem kailangan da w palitan.. nagpunta ko sa nissman sa masangcay sabi naman nila baka daw sensor problem.. nabangga kasi yung sa driver side ng kotse ko.. ano po sa tingin possibleng problema nito?
    May 2007
    Check the fluid level,check owners manual if lost than follow these steps:
    1. Drive the vehicle at least 10 kilometers
    2. park the car
    3. engage parking brake
    4. shift selector through all gear ranges with foot on brake pedal
    5. return shifter back to park
    6. leave engine on
    7. check fluid level be sure vehicle is on level ground. if fluid is low check owners manual to see what type of fluid it uses, if fluid is at correct level then have fluid/filter serviced. This time change the filter, not cleaning the filter.
    Check the tranny mount too. Its hard to tell if the mount are good or bad if you dont remove it from the tranny.
    ok sir v6dreamer.. try ko po advice nyo.. thank you.
    Apr 2011
    sir ano po exactly naging sira ng auto trans nyo
2003 exalta granduer transmission problem b?
