Good day all! konti advice lang bakit kaya namamatay stereo ko at bumubukas ulit. ano kaya ang dahilan at dapat ko patignan? salamat..
Pa bless mo baka may multo.
Ano yan sir pag namatay nagre-reset, as in nawawala ang stored channels and settings sa memory? In case na ganyan nga e nawawalan ng power, so check mo ang power supply. Baka may loose wiring, loose fuse o fuse na malapit na mapundi.
Naka amp ka ba? Most probably nag protect mode yan dahil sa init. Di well ventilated amp mo and masyado malakas volume mo kaya overheat.
sir yebo.. hindi nmn siya nag rereset, nmmtay lang at bumblik sa dati. bumubkas ulit.! minsan talagang off n..kailngan mong on ulit..
sir ghosthunted, parang nga shorted connection...pano ba ma diagnose ganito cause.. ? tinignan ko nmn mga wiring sa likod ng hu o.k nman lhat..puwede den ba sa ibang wiring shorted..? or may sira na head unit ko.?
Only way to check is to let an auto electrician check your car's wiring, especially if you have a lot of cut & spliced wiring jobs done in the past. He'll try to trace it from the fuse block to the headunit. Worst case, maybe install new wires from the fuse block to the headunit just to help eliminate the cause of the problem.
If there are other "activities" in the cars electronics that triggers ur HU to turn off, then it might be that you'rr having problems sa power source mo. It might be yung alternator (baka kulang yung amp rating to power all ur electronics?) Or yung electrical connections as per GH.
Sent from my GT-I9300 using Tapatalk
