Results 1 to 10 of 10
    My wife car a nissan sentra '98 model fail to start when it switch on the ignation the engine roll but it never revive. Fuel, Battery and Fuse are all okay. Any idea what other causes of non start of engine?
    Quote Originally Posted by FungZhou View Post
    first thing to do is to have a scan test and go from there
    the scanner will be able to check if there is a major component faliure that's causing the no start condition
    May 2007
    WTF bagong bago. Pa towing mo doon sa casa may warranty pa iyan.
    Sep 2008
    Ay! baka namali ng basa si V6, '98 po hindi '08 ang oto daw.:peace:
    May 2007
    Quote Originally Posted by chevy81 View Post
    Oo nga pala ano!
    Apr 2008
    ano po reaction pag nasusi ka?
    Jun 2007
    I have the same problem. Parehong pareho po yung nangyayari pero we checked further, we removed the high tension wires from the distributor cap to check if it fires pero walang lumalabas na electricity from the distributor. We checked naman yung wires going to it we got a good reading of 12V. Can we say na nasa loob ng distributor ang problema? Pero anong part ng distributor? Can someone tell me please pano kalasin yung distributor assembly para mapa-check ko.. TY
    Jan 2009
    sir, meron ako ditong Nissan Sentra 98 Factory Service Manual baka gusto nyo...
    Nangyari sakin yan last week. Medyo five days ko hindi nagamit yung sentra 2003 ko. As in di ko talaga na start or napainit man lang sa five days na yun. nung sixth day, start ko siya nung umaga at nilipat ko sa kabilang parking namin. Bale, di pa umiinit yung makina pinatay ko na agad. pagbalik ko na bahay ng 7th day, nag start naman agad pero namatay din. pina check ko sa mekaniko, na-foul yung spark plugs. apparently, may mga fuel injected cars na pag matagal mo hindi ginamit na fofoul yung plugs. Nangyayari lang iyon kapag na start mo na siya at ginalaw mo yung car at pinatay yung makina ng hindi pa mainit. May naiiwang unburned fuel sa plugs. Kaya ayun, ininit lang yung plugs oks na. Kinabukasan, pumunta ako sa shop at bumili ng platinum plugs. hehe.
    1st thing I learned from my Overheating S4 ''98 model is that it wont allow me to crank my Engine above Engine temperature Preset sa ECU. happen to me 2x when I failed to Rekta my Aux fans.
    2nd thing that I learned is that the small Terminal lead above the starter Loosen, it's hidden by the air intake manifold.( medyo mahirap abutin )
    3rd My S4 '98 being an A/T needs to be on P or N before starting, found out that the Limit switch sometimes fail & wont give me permissive to start.
Nissan Sentra '98 model won't start
