Results 1 to 20 of 22
    May 2010
    Hi, Sir Mam, Need some help, how can i, or what can i do to save some gas from may Nissan LEC Ps Model? What should i do, Hope any one can help me on in. Tnx in advance. Carb engine
    ... errr... use your car less?
    seriously, you might want to start playing with the jets. experiment with smaller jet size. but i don't know where you can get 'em anymore.
    Quote Originally Posted by bounds30 View Post
    You can cut your fuel costs by 1/3 to almost 1/2 by converting to Auto-LPG. The savings vary depending the the price difference between gasoline & lpg during the year.
    A carb type conversion to auto-lpg should be between 14K to 18K. Depending on your amount of use, the conversion can pay for itself (in cost savings) between a year to two years.
    Apr 2004
    whoa... mura na lang ha... i think it used to be 25-30K for carb cars di ba sir GH?
    i wonder how much for EFI V6 cefiros?
    to the threadstarter:
    dude ganyan yata talaga nissan sentra na carburator pa ang fuel system. nagkameron din kami nyan, ex saloon nga lang, parang LEC din with power steering nga lang.
    i had one of the carb expert guys in kamuning replace the carburettor jets with smaller ones and then tune the engine to run lean, that is, more air but less fuel.
    tumipid nga, pero ang panget ng takbo. parang taxi na karag-karag. if you can live with this, then eto pagawa mo.
    else, you can just ensure na malinis lagi ang air filter mo (carb cars are sensitive like that), laging tune up, palit ng mas malabnaw na langis (10w-30 will do) at magmaneho ng mahinahon.
    May 2008
    lower engine oil weight might cause the engine to run hotter specially in older engines. if this happens, you can try cooler plugs but with the ethanol/gasoline blend, the engine will probably be sluggish. try lowering the a/c thermostat to half the range.
    May 2010
    tnx sir any sudjestion on engine? to save more on it
    Apr 2008
    I've always thought that LEC-PS Sentras were DOHC 16 valve EFI's. Or is it only pertaining to the earlier models? I have a relative who owns one, and its true that it consumes quite a lot for a 1.3 liter. As for fuel saving, I'd say shift earlier (perhaps you can invest in an aftermarket tach), take it easy with the right foot, get the right tire pressure for your car and clean/replace the filters. That should help you save some. BTW, what kind of FC do you get?
    Aug 2010
    Question: Is converting to LPG worth it for a '94 Nissan LEC?
    Quote Originally Posted by Gabe_Logan View Post
    Depends on how much you drive (average per month??) and how long you will plan to keep the car.
    Also is there an Auto-LPG station nearby your work/home?
    I recently started using a B13 1.4L as an extra car. At first we would get a dismal 7km/L in city driving. We overhauled the carb, tuned-up the engine (change plugs, adjusted the timing and idling). We now do 10km/L mixed with a driving style of driving with a light foot, having the A/C set at half and shifting as early as possible without "stressing" the engine.
    Also pondering on doing a carb LPG swap (was quoted around 16K i think) but it still depends on whether we decide to use this car more often or not.
    You might end up using the B13 more often if you have it running on Auto-LPG because fuel costs will become cheaper.
    Aug 2010
    Hello there. I think we have the same problem. I drive a '94 Nissan Sentra LEC. Recently, I had to replace my distributor since the car would not start. When it was replaced, had to see a mechanic again since the car's performance is sluggish. According to him, kapag pinalitan ang distributor, kailangan din syang i-tono. The performance became excellent (better than before) but I started emitting thick white smoke (para syang usok ng dalawang tricyle). That's when my fuel consumption started to increase. Before, I can log in around 10km to a liter. It became something like 5 or 6. I was advise by the mechanic for an engine overhaul and at the same time, replacement of the timing chain. The smoke is now gone, but my fuel consumption is some what the same. I would appreciate any advice. Thanks.
How Can I Save Some Gas From My Nissan LEC PS?
