Results 1 to 8 of 8
    Aug 2012
    lumubog po un kotse up to hood ang sa garahe pero disconnected ang battery nun nangyari. nilinis ko ang lahat fuses,fusible links, relays, at clean and blow dried ang mga electronic ckts. including the ecu. distributor and ignition coil was clean also.change oil, gear oil and filters before starting it. unfortunately, engine was cranking but dont start, i check my distributor/ignition coil kun may voltahe meron naman,possible po ba mga bossing na sira na ecu ko.fuel pump is giving gas but to no avail walang sparks ang HTW ko. i tried replacing the distributor still same result pa rin.please advise po mga bossing what to do.......
    Jun 2007
    ^ it wont hurt naman siguro if mag pa home service ka sa autorized Nissan mechanic
    Aug 2012
    olongapo kasi ang area ko kaya umasa na lang ako sa mekaniko ko.di rin nya kasi masabe kun may tama na ecu....
    May 2009
    Try mo magpalit ka ng HTW at spark plugs.. tapos linisin mo na din yung Throttle Body, MAF sensor, IACV, etc. kung hindi mo pa nalinis?
    Aug 2012
    nalinis ko na din sir un TB, spark plugs except maf sensor at iacv boss mafers.un HTW naman ay buo chinek ko ng ohm meter.ty sir mafers sa advice.pa check ko na siguro sir un ecu ko..
    May 2009
    A tip's from Sir Tevs (ClubNissanSentra Baguio)
    For EFI Cars:
    Here is what i would do.
    1. Remove Battery from car
    2. Remove ECU - use 10mm socket wrench - for Sentra's its located in the bottom middle part just above where the Driver's Gas Pedal is to the right. kapag napasukan nang putik ang ECU - use Distilled water to clean it and final clean with electrical contact cleaner - make sure not to create any static and make sure you are properly grounded when touching the ECU
    3. Hose Down entire Engine bay to remove mud and debris - now would be a good time to wash the entire car as well
    4. Now is the time to clean and degrease/Detail the engine, then rinse down properly.
    5. Disconnect MAF, TPS Pigtail connections - Let these Air Dry under the sun, clean AICV with carb cleaner and let air dry, remove air filter, replace or clean
    NOTE: - Remove ENtire MAF Assembly from intake tube - Clean MAF Hotwire Sensor with carb cleaner - spray at a distance enough to clean the wire - not too close so you wont damage the hotwire sensor within the MAF Assembly
    6. remove intake tube leading to throttle body
    - open Distributor CAP & Rotor and clean/flush with distilled water and let air dry if pinasukan nang putik - if wet- just let it air dry
    7. Clean the Intake Manifold with a rag to remove as much Debris/Mud or Dirt - clean the throttle body as well.
    8. Drain Oil, remove Oil filter, Drain Transmission Fluid, Drain Gas, bleed entire brake system to take out the old brake fluid, pull sparkplugs, clean and let air dry
    9. now is a good time to do underwash.
    10. pull out all your interior - panels, seats, carpet, everything that you can take out and Hose down the entire interior.
    baka makatulong..
nissan series 3 97 model  ecu or what?
