Results 1 to 4 of 4
    Jul 2011
    Hi! Does anyone know what engine is installed in a Kawasaki HD3?
    Yung specs nya and all (power curve, max torque..)
    Thanks!
    -danver
    Feb 2012
    engine - 2 stroke, single cyclinder rotary disc valve
    displacement - 124cc
    bore and stroke - 55 x 52.5 mm
    compression ratio - 6.4:1
    max horsepower - 13 hp / 6,500 rpm
    max tourque - 1.45 kg-m/ 5,000 rpm
    accelaration -11.5sec. ss 0-200m
    19.6.sec. ss 0-400 m
    transmission
    type - 4 speed, constant mesh rotary shift
    shift pattern - n-1-2-3-4-n
    clutch - wet, multi disk...
  3. #3
    How does this rotary disc valve work? I already knew some 2-stroke engines had reed intake valves and a power valve at the exhaust...
    Feb 2012
    kawasaki hd3 :D
Kawasaki Engine
