Medyo tight kasi ang space where I park and nagasgasan front bumper ko when I accidentally hit the wall.Meron bang mabibilhan dito?
sa true value may nabibiling wheel choke. parang 600 yata per pair.
sa true value eastwood ko nakita.
Yup, pwede ring DIY..pieces of brick wood/coco lumber and plywood will do...Will you have this always handy or maiiwan na dun sa parking space?
Sa garahe gamit ko pvc pipe attached to a can filled with concrete. Epektib naman. Another option is to put tapes on the side walls and line it up with your side mirrors for reference.
Thanks. I tried ace and Concorder walang ganun... Will check out Handyman and True Value. Kung wala will try to DIY na lang or order sa States.
Mateomarco, I need to have it fixed on the floor so kailangan i-drill.
Kung fix sa floor ng garage, make sure na yung mabibili ninyo could withstand water or in short, outdoor elements...Hard plastic or rubber will do...Kung DIY, pwedeng cement or steel...hindi pwede wood
