Results 1 to 10 of 14
- Sep 2005
- 79
March 23rd, 2006 12:43 PM #1hi mga paj owners tanong lang po when is the best time to use the 'hold' transmission mode? most of the time kasi nasa economy mode lang ako.
salamat po
March 23rd, 2006 04:59 PM #2
When you do not want the transmission constantly 'hunting' between gears.
E.g. towing uphill, going downhill especially on traction-compromised surfaces (sand, loose gravel, etc.)
March 23rd, 2006 08:01 PM #3
read sa manual the hold button is used only when the gear lever is stuck. Lets say in park when you press the button on the side and it wont move you press the hold button to release the locking mechanism to move to R or D
March 23rd, 2006 10:44 PM #4
March 24th, 2006 01:31 AM #6
HOLD will tell your a/t to upshift as soon as possible, so that you do not rev too much.
please try to do a search, this has been answered na in the past.
- Sep 2005
- 79
March 24th, 2006 11:20 AM #7thanks po. so i guess it should be more economical when driving in highway with hold mode since i will not revving that much. tama po ba.
March 24th, 2006 11:49 AM #8
Nope. Standard configuration is still the most economical. Just keep the O/D on so that you can utilize fourth gear. With O/D off, hanggang 3rd gear ka lang.
March 24th, 2006 01:38 PM #9
pasingit lang
my gen2 A/T JDM pajero doesnt have a hold button... anyway cruising at highway, only till it reaches 65kph does it upshift to fourth, now dos this mean that if i can activate the hold button, i would upshift to fourth gear earlier than 65kph???
tia!
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
