Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    sa mga adventure owners po... have you experience na may tagas yung drain plug sa radiator..
    my ride is 2012 Advie GLX... napansin ko nababawasan yung coolant. Nung nag inspect ako I notice na may tagas yungdrain plug ng radiator.. sabi sa shell teflon lang daw nilalagay nila dun..
    anu po sa tingin nyo..
    May 2011
    or palit drain plug
    Apr 2009
    Quote Originally Posted by japeeps View Post
    Nagkaproblem na din ako ng ganito dati sa 2003 Advie SS namin. Teflon tape did stopped the leak. But make sure hindi loose thread yung drain plug. Otherwise, replace it. :-)
    i check mo na lang din yan every now and then...... pero mura lang naman magpalit ng drain plug eh....
    teflon lang yan ganyan din sa hilander ko nun hindi naman nagkaproblema hanggang naibenta ko
    may O-ring ba yun drain plug? palitan mo na din kung meron, baka matigas na.
    Sep 2013
    di advisable na gamitin ang teflon sa drain plug. may possibly na malusaw ito sa sobrang init ng makina kaya may possibly din magka leak oil. ang mura lang naman ng OHR O-ring so hwag na sanang makipagsapalaran.
    try replacing the washer or o-ring of the drain plug, as the bench suggested.
    teflon tape? well, it's got a pretty high melting temp.. it is used in non-stick frying pan surfaces.. but i am not sure of its resistance against oil..
    i am more comfortable with washers in cars. siguro kung nawasa pipe..
    Sep 2013
    with all due respect pls, ang isang gamit ng washer ay para di mag grind/rub together ang bolt sa substrate kapag tightening ang bolt. so ang washer ay ang protection sa substrate pag tightening ang bolt. hence applying this principle in a car, aluminum engine block = drain plug for substrate = bolt respectively.
    Feb 2009
    What the doc was implying was copper or aluminum gasket similar to those used in Beater Double U and Mercedes beans
tagas sa drain plug ng radiator
